Discuss
Whirlpool gas dryer high heat only.
 in
Dryer Repair
Dryer runs on high heat only.Timer advnces on timed setting, but not on auto settings. Low heat auto setting runs
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool gas dryer high heat only.
  #1 (permalink)
Old 11-01-2010, 05:01 PM
Junior Member
dbaro is on a distinguished road
Default Whirlpool gas dryer high heat only.
Model Number: LGR4634EQ0   Brand: Whirlpool   Age: 5 - 10 years
Dryer runs on high heat only.Timer advnces on timed setting, but not on auto settings. Low heat auto setting runs on high heat only, and does not advance the timer. Air fluff setting does not advance, and runs on high heat only. Dryer worked fine until thermal fuse blew. Replaced it, and since then the problem described started. Have replaced the high heat thermostate as well as the cyclic thermostate. Have gone completely through and cleaned everything, so no obstuctions. I don't believe there is a dryness sensor on this model??
Ads By Google
Related Models
Whirlpool LGR4634EQ0 GAS DRYER
Whirlpool LGR4634EQ1 GAS DRYER
Whirlpool LGR4634EQ2 GAS DRYER
Whirlpool LGR4634EQ3 GAS DRYER
Whirlpool LGR4634EW0 GAS DRYER
Whirlpool LGR4634EZ0 GAS DRYER
Whirlpool LGR4634EZ1 GAS DRYER
Whirlpool LGR4634EZ2 GAS DRYER
Whirlpool LGR4634EZ3 GAS DRYER
Whirlpool LGR4634JQ0 GAS DRYER
Whirlpool LGR4634JQ1 GAS DRYER
Whirlpool LGR4634JQ2 GAS DRYER
Whirlpool LGR4634JQ3 29" GAS DRYER
Whirlpool LGR4634JT0 GAS DRYER
Whirlpool LGR4634JT1 GAS DRYER
Whirlpool LGR4634JT2 GAS DRYER
Whirlpool LGR4634JT3 29" GAS DRYER
Whirlpool LGR4634JZ0 GAS DRYER
Whirlpool LGR4634JZ1 GAS DRYER
Whirlpool LGR4634PQ0 29" GAS DRYER
Whirlpool LGR4634PQ1 29" GAS DRYER
Whirlpool LGR4634PT0 29" GAS DRYER
Whirlpool LGR4634PT1 29" GAS DRYER
Whirlpool LGR5434AW0 Residential Dryer
Whirlpool LGR5600HQ0 GAS DRYER
Whirlpool LGR5600HZ0 GAS DRYER
Whirlpool LGR5600JQ0 GAS DRYER
Whirlpool LGR5600JQ1 RESIDENTIAL DRYER
Whirlpool LGR5600JT0 GAS DRYER
Whirlpool LGR5600JT1 RESIDENTIAL DRYER
Whirlpool LGR5620KQ0 RESIDENTIAL DRYER
Whirlpool LGR5620KQ1 GAS DRYER
Whirlpool LGR5620KQ2 29"GAS DRYER
Whirlpool LGR5624BN0 GAS DRYER
Whirlpool LGR5624BN1 GAS DRYER
Whirlpool LGR5624BN2 GAS DRYER
Whirlpool LGR5624BW0 GAS DRYER
Whirlpool LGR5624BW1 GAS DRYER
Whirlpool LGR5624BW2 GAS DRYER
Whirlpool LGR5624DQ0 DRYERS
Whirlpool LGR5624DQ1 DRYER
Whirlpool LGR5624DW1 DRYER
Whirlpool LGR5624DZ0 DRYERS
Whirlpool LGR5624DZ1 DRYER
Whirlpool LGR5634AN0 GAS DRYER
Whirlpool LGR5634AQ0 GAS DRYER
Whirlpool LGR5634AQ1 GAS DRYER
Whirlpool LGR5634AQ2 GAS DRYER
Whirlpool LGR5634AW0 Residential Dryer
Whirlpool LGR5634DQ1 DRYER
Whirlpool LGR5634EQ0 GAS DRYER
Whirlpool LGR5634EZ0 GAS DRYER
Whirlpool LGR5634LQ0 RESIDENTIAL DRYER
Whirlpool LGR5635LQ0 29"GAS DRYER
Whirlpool LGR5635LQ1 29"GAS DRYER
Whirlpool LGR5636DW0 DRYER
Whirlpool LGR5636DW1 DRYER
Whirlpool LGR5636EQ0 DRYER
Whirlpool LGR5636EQ1 DRYER
Whirlpool LGR5636EQ2 DRYER
Whirlpool LGR5636EQ3 DRYER
Whirlpool LGR5636EZ0 DRYER
Whirlpool LGR5636EZ1 DRYER
Whirlpool LGR5636EZ2 DRYER
Whirlpool LGR5636EZ3 DRYER
Whirlpool LGR5636JQ0 DRYER
Whirlpool LGR5636JQ1 DRYER
Whirlpool LGR5636JT0 DRYER
Whirlpool LGR5636JT1 DRYER
Whirlpool LGR5636KQ0 DRYER
Whirlpool LGR5636KQ1 DRYER
Whirlpool LGR5636KT0 DRYER
Whirlpool LGR5636KT1 DRYER
Whirlpool LGR5636LG0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ1 29"GAS DRYER
Whirlpool LGR5636LT0 RESIDENTIAL DRYER
Whirlpool LGR5636LT1 29"GAS DRYER
Whirlpool LGR5636LW0 RESIDENTIAL DRYER
Whirlpool LGR5636PQ0 29"GAS DRYER
Whirlpool LGR5636PQ1 29"GAS DRYER
Whirlpool LGR5636PT0 29"GAS DRYER
Whirlpool LGR5636PT1 29"GAS DRYER
Whirlpool LGR5638AN1 GAS DRYER
Whirlpool LGR5638AN2 GAS DRYER
Whirlpool LGR5638AN3 GAS DRYER
Whirlpool LGR5638AW0 Residential Dryer
Whirlpool LGR5638AW1 GAS DRYER
Whirlpool LGR5638AW2 GAS DRYER
Whirlpool LGR5638AW3 GAS DRYER
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2 GAS DRYER
Whirlpool LGR5644AW0 Residential Dryer
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2 GAS DRYER
Whirlpool LGR5644EQ0 GAS DRYER
Whirlpool LGR5644EQ1 DRYERS
Whirlpool LGR5644EQ2 GAS DRYER
Whirlpool LGR5644EQ3 GAS DRYER
Whirlpool LGR5644EZ0 GAS DRYER
Whirlpool LGR5644EZ1 DRYERS
Whirlpool LGR5644EZ2 GAS DRYER
Whirlpool LGR5644EZ3 GAS DRYER
Whirlpool LGR5644JQ0 GAS DRYER
Whirlpool LGR5644JQ1 RESIDENTIAL DRYER
Whirlpool LGR5644JQ2 GAS DRYER
Whirlpool LGR5644JQ3 29" GAS DRYER
Whirlpool LGR5644JT0 GAS DRYER
Whirlpool LGR5644JT1 RESIDENTIAL DRYER
Whirlpool LGR5644JT2 GAS DRYER
Whirlpool LGR5644JT3 29" GAS DRYER
Whirlpool LGR5644PQ0 29" GAS DRYER
Whirlpool LGR5644PQ1 29" GAS DRYER
Whirlpool LGR5700KQ0 DRYER
Whirlpool LGR5700KQ1 DRYER
Whirlpool LGR5700KT0 DRYER
Whirlpool LGR5700KT1 DRYER
Whirlpool LGR5848EQ0 GAS DRYER
Whirlpool LGR5848EQ1 GAS DRYER
Whirlpool LGR5848EQ2 GAS DRYER
  #2 (permalink)
Old 11-01-2010, 08:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely the problem is a bad coils on the gas valve.
- The coil kit Part number: AP3094251
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR4634EQ0 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-01-2010, 08:47 PM
Junior Member
Default
Thanks for the fast reply. Guess I forgot to include the fact that I also changed both the coils already. Is it possible that the replacements might have been bad, or that they could have gone out?
Should I try changeing them again? Could it be the timer?
Thanks again.
  #4 (permalink)
Old 11-05-2010, 07:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sorry for the delay.
Looks like the problem can be a bad timer.
Label all wires and remove them from the timer. Set the timer on auto-low heat and check for continuity across the terminals: TM-OR, BK-BU-V, BK-BU and BK-R. If there is no continuity in any pair, replace the timer.
- The timer Part number: AP2976148
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Whirlpool Dryer will not start on high heat cycle aphan9 Dryer Repair 0 06-27-2010 10:42 AM
Hotpoint Dryer only has heat on High carterspeed Dryer Repair 0 03-25-2010 12:07 PM
frigidaire dryer doesn't heat on high setting Alexis46 Dryer Repair 1 09-27-2009 07:55 PM
Whirlpool electric Dryer runs on High heat Highlander Dryer Repair 2 10-01-2008 06:28 PM
