Discuss
frigidaire dryer runs 15 minutes and stops
 in
Dryer Repair
My dryer runs for about 15 minutes and then stops. Then all of the lights are flashing, but way faster
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » frigidaire dryer runs 15 minutes and stops
  #1 (permalink)
Old 10-28-2010, 12:33 PM
Junior Member
phil12357 is on a distinguished road
Default frigidaire dryer runs 15 minutes and stops
Model Number: LEQ1442ES0   Brand: Frigidaire   Age: 1 - 5 years
My dryer runs for about 15 minutes and then stops. Then all of the lights are flashing, but way faster than they do for any of the diagnostics or error codes (and they seem to go on forever). It doesn't feel like it is getting warm inside the drum. If I hit cancel and restart, I can usually restart right away, but in 15 minutes it stops again.
Someone suggested it might be a control board, so I replaced that, but I get the same issue.
Any thoughts? I've tried to search the forums, but haven't run into very much that sounds like this (one thread but it's missing any comments on what the problem ended up being). I'm pretty much an amateur, so if there are specific checks I can do, instructions or links that help out would be greatly appreciated.
Thanks!
Ads By Google
Related Models
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ1442ES1 DRYER
Frigidaire LEQ1452KS0 DRYER
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152EE1 DRYER
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ2152HS0 DRYER
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0 DRYER
Whirlpool LEQ5000KQ1 29"ELECTRIC DRYER
Whirlpool LEQ5000KQ2 29"ELECTRIC DRYER
Whirlpool LEQ5000KW1 29"ELECTRIC DRYER
Whirlpool LEQ5000KW2 29"ELECTRIC DRYER
Whirlpool LEQ5000PW0 29"ELECTRIC DRYER
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ6400FS0 DRYER
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0 DRYER
Whirlpool LEQ7000KQ1 DRYER
Whirlpool LEQ7000KQ2 DRYER
Whirlpool LEQ7030KQ0 DRYER
Whirlpool LEQ7030KQ1 RESIDENTIAL DRYER
Whirlpool LEQ7030KQ2 29"ELECTRIC DRYER
Frigidaire LEQ8000FE0 DRYER
Whirlpool LEQ8000HQ0 DRYER
Whirlpool LEQ8000HQ1 DRYER
Whirlpool LEQ8000JQ0 DRYER
Whirlpool LEQ8000JQ1 DRYER
Whirlpool LEQ8000JQ2 DRYER
Whirlpool LEQ8000JQ3 29"ELECTRIC DRYER
Whirlpool LEQ8000JQ4 ELECTRIC DRYER
Whirlpool LEQ8100KQ0 DRYER
Whirlpool LEQ8100KQ1 DRYER
Whirlpool LEQ8100KT0 DRYER
Whirlpool LEQ8100KT1 DRYER
Whirlpool LEQ8611LG0 RESIDENTIAL DRYER
Whirlpool LEQ8611LG1 27"ELECTRIC DRYER
Whirlpool LEQ8611LW0 RESIDENTIAL DRYER
Whirlpool LEQ8611LW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG0 27" ELECTRIC DRYER
Whirlpool LEQ8611PG1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG2 27"ELECTRIC DRYER
Whirlpool LEQ8611PW0 27" ELECTRIC DRYER
Whirlpool LEQ8611PW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PW2 27"ELECTRIC DRYER
Whirlpool LEQ8621PG0 27" ELECTRIC DRYER
Whirlpool LEQ8621PG1 27"ELECTRIC DRYER
Whirlpool LEQ8621PG2 27"ELECTRIC DRYER
Whirlpool LEQ8621PW0 27" ELECTRIC DRYER
Whirlpool LEQ8621PW1 27"ELECTRIC DRYER
Whirlpool LEQ8621PW2 27"ELECTRIC DRYER
Whirlpool LEQ8800JQ0 DRYER
Whirlpool LEQ8800JQ1 DRYER
Whirlpool LEQ8800JT0 DRYER
Whirlpool LEQ8800JT1 DRYER
Whirlpool LEQ8857HQ0 DRYER
Whirlpool LEQ8857HQ1 DRYER
Whirlpool LEQ8857HZ0 DRYER
Whirlpool LEQ8857HZ1 DRYER
Whirlpool LEQ8857JQ0 DRYER
Whirlpool LEQ8857JQ1 DRYER
Whirlpool LEQ8857JT0 DRYER
Whirlpool LEQ8857JT1 DRYER
Whirlpool LEQ8858HQ0 DRYER
Whirlpool LEQ8858HQ1 DRYER
Whirlpool LEQ8858HZ0 DRYER
Whirlpool LEQ8858HZ1 DRYER
Whirlpool LEQ8858JQ0 DRYER
Whirlpool LEQ8858JQ1 DRYER
Whirlpool LEQ8858JT0 DRYER
Whirlpool LEQ8858JT1 DRYER
Whirlpool LEQ8858JZ1 DRYER
Whirlpool LEQ9030PQ0 29"ELECTRIC DRYER
Whirlpool LEQ9030PQ1 29" ELECTRIC DRYER
Whirlpool LEQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9508LG0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW0 RESIDENTIAL DRYER
Whirlpool LEQ9508LW1 29"ELECTRIC DRYER
Whirlpool LEQ9508PG0 29"ELECTRIC DRYER
Whirlpool LEQ9508PG1 29" ELECTRIC DRYER
Whirlpool LEQ9508PW0 29"ELECTRIC DRYER
Whirlpool LEQ9508PW1 29" ELECTRIC DRYER
Whirlpool LEQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9557KT1 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9558KT0 RESIDENTIAL DRYER
Whirlpool LEQ9558KT1 RESIDENTIAL DRYER
Whirlpool LEQ9857LG0 RESIDENTIAL DRYER
Whirlpool LEQ9857LG1 29"ELECTRIC DRYER
Whirlpool LEQ9857LW0 RESIDENTIAL DRYER
Whirlpool LEQ9857LW1 29"ELECTRIC DRYER
Whirlpool LEQ9857PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858LG0 RESIDENTIAL DRYER
Whirlpool LEQ9858LG1 29"ELECTRIC DRYER
Whirlpool LEQ9858LW0 RESIDENTIAL DRYER
Whirlpool LEQ9858LW1 29"ELECTRIC DRYER
Whirlpool LEQ9858PG0 29"ELECTRIC DRYER
Whirlpool LEQ9858PG1 29"ELECTRIC DRYER
Whirlpool LEQ9858PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858PW1 29"ELECTRIC DRYER
Whirlpool LEQ9957KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9957KT0 RESIDENTIAL DRYER
Admiral LER1115AAW RANGE- F/S STD ELE
Whirlpool LER2614BW0 ELECTRIC DRYER
Whirlpool LER2614BW1 ELECTRIC DRYER
Whirlpool LER2614BW2 ELECTRIC DRYER
Whirlpool LER2614DW0 ELECTRIC DRYER
Whirlpool LER2614DW1 ELECTRIC DRYER
Whirlpool LER2614EW0 ELECTRIC DRYER
Whirlpool LER2614EW1 ELECTRIC DRYER
Whirlpool LER2614EW2 ELECTRIC DRYER
Whirlpool LER2614JQ0 ELECTRIC DRYER
Whirlpool LER2614JQ1 ELECTRIC DRYER
  #2 (permalink)
Old 10-29-2010, 03:20 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for FRIGIDAIRE LEQ1442ES0 Frigidaire/dryer | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodin...509400efsa.pdf
And a manual
http://frigidaireservicetips.com/pdfs/487_2.pdf
Note: I have never seen this so the following is just what I would do.
That you can restart the unit right after it shuts off is an important symptom.
Often dryer shut down is due to the motors internal thermal protect tripping but you would have to wait for the motor to cool down and the thermal protect to reset. I am assuming this is not the case.
Try to get into the diagnostics to see if the control board has stored an error code.
If no codes, the first thing I would do is check the power. (see below)
You may want to try different modes to see if it does it on all modes (auto and timed dry, with and without heat)
It could be that the board monitors the temperature and is shutting down/erroring out due to the no heat condition.
If power is good I would check the heating element, the hi-limit thermostat, the thermal limiter and the thermistor for resistance.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Sorry that I cannot be more helpful but hopefully the above will be of some use.
__________________
  #3 (permalink)
Old 10-29-2010, 06:30 AM
Junior Member
Default
Thanks for the response. I played around with it a bit more yesterday, but haven't completely solved it.
Here's a newbie question: is the heating element the same as the heating element assembly? I would assume not, but I cannot find heater element within the parts list on this site or a couple others. I'm just trying to price out everything to see how much value there is in continuing to mess with it.
Thanks again!
  #4 (permalink)
Old 10-29-2010, 06:53 AM
Senior Expert
APP Volunteer
Default
I would say, yes.
If you click on the picture another view of the parts will open.
You can then click on it to see the element side of the assembly
Part number: AP2107129
__________________
  #5 (permalink)
Old 11-04-2010, 08:11 AM
Junior Member
Default
It was the heating element. After taking everything apart it was pretty apparent that the element was in bad shape. Then I put one finger on it and found that the coil had actually broken. Got it swapped out and reassembled and it looks like everything is working fine.
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator runs a long time then stops for only 5 minutes Sam94 Refrigerator & Freezer Repair 2 05-15-2010 02:02 PM
dryer stops after 4 or 5 minutes OHKel Dryer Repair 0 03-22-2010 07:49 AM
Dryer stops after a few minutes gerggarry Dryer Repair 3 02-13-2010 07:46 AM
dryer runs AND heats for 10 minutes then stops heating and turning awaywardson Dryer Repair 7 04-24-2009 09:00 AM
runs for a few minutes and stops FISHMASTER70 Dryer Repair 8 09-17-2008 07:34 PM
