My dryer seems to heat up excessively when drying a load of clothes. They are almost too hot to touch when taking them out. I thought at first that the vent may be clogged, but I cleaned it out and it still does it. Any ideas on what might be the culprit? Thanks for any help.
Originally Posted by: toolguy47 My dryer seems to heat up excessively when drying a load of clothes. They are almost too hot to touch when taking them out. I thought at first that the vent may be clogged, but I cleaned it out and it still does it. Any ideas on what might be the culprit? Thanks for any help. Toolguy, Did you check for a shorted heater element ? It may have broke and shorted to the element casing. Do you have a thermometer or temperature meter so you can check for 155(+/-10%) degrees at the exhaust vent on the dryer, with the vent off ? That would be the next step, were it me. Good Luck, :) :) :)
