Discuss
have heat for a few minutes then gone
 in
Dryer Repair
my gas dryer has heat for about 5 minutes then it is gone. the fuse has source voltage and the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » have heat for a few minutes then gone
  #1 (permalink)
Old 10-27-2008, 07:41 PM
mikejcars mikejcars is offline
Junior Member
mikejcars is on a distinguished road
Default have heat for a few minutes then gone
Model Number: estate   Brand: Whirlpool   Age: 5 - 10 years
my gas dryer has heat for about 5 minutes then it is gone. the fuse has source voltage and the other sensor in the air outlet has 120volts at all four wires it seamed the switch went open then closed. after that you can see the ignition glowing but no more flame. if it sits off for a few minutes it will ignite again and do the same thing
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-27-2008, 08:05 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
it sound as if the gas valve solonoids are failing
__________________
  #3 (permalink)
Old 10-27-2008, 08:35 PM
Junior Member
Default
could the mode timer switch have anything to do with this it was stuck on some settings and moves on others opened up the switch and contacts were burned up I ordered it and re installed now I have this problem. tried to clean the contacts did not do anything. have not received new timer yet
  #4 (permalink)
Old 10-27-2008, 08:52 PM
Senior Expert
APP Volunteer
Default
try replacing burner valve solonoids
__________________
  #5 (permalink)
Old 10-27-2008, 08:56 PM
Junior Member
Default
any idea on how to get them the model # dose come up and I have no idea how old this is it was in the house when bought
  #6 (permalink)
Old 10-27-2008, 09:10 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
What's your model number?
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #7 (permalink)
Old 10-28-2008, 06:04 AM
Senior Expert
APP Volunteer
Default
if you open door you should see sticker on body where door meets body
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Flame Goes out after a few minutes chinahorse Dryer Repair 3 12-12-2008 10:55 PM
Gas Flame Goes out after a few minutes chinahorse Dishwasher Repair 0 09-12-2008 02:26 PM
kenmore dryer heat cuts out after a few minutes stumpedagain Dryer Repair 0 08-22-2008 08:06 PM
Dryer shuts off after about 10 minutes charysemcdaniel Dryer Repair 1 08-10-2008 08:42 PM
Burner shuts off after a few minutes Adnan Oven Repair (including Ranges and Cooktops) 4 05-14-2008 05:45 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
