Discuss
How to replace drum rollers
 in
Dryer Repair
I recently replaced the belt. The dryer started making a squeaking sound and in time eventually started getting louder and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How to replace drum rollers
  #1 (permalink)
Old 10-27-2008, 05:47 PM
recky64 recky64 is offline
Junior Member
recky64 is on a distinguished road
Default How to replace drum rollers
Model Number: ale866saw   Brand: Amana   Age: 5 - 10 years
I recently replaced the belt. The dryer started making a squeaking sound and in time eventually started getting louder and was making a rumbling noise. I took front off and seen the one drum roller is broke. How do I replace them and should I replace the idler pulley while I'm doing all this work?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-27-2008, 08:08 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
As long as the shaft isn't bent you can probably replace just the rollers. If in doubt replace the other part as well.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 10-28-2008, 05:42 AM
kayakcrzy kayakcrzy is online now
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
I would replace the idler pully too. To replace the rollers, on the one to the right just cut the nylon triangle clip, that holds the roller in place, and the one on the left, you have to take the 5/16 screw that holds the bracket to the base, and then wiggle the bracket off, and the tab, that holds on the top part will come off with it. Then cut the nylon, triangle clip off that one, and replace. Tom ApplianceEducator.com
  #4 (permalink)
Old 11-11-2008, 01:02 PM
robert scholtes robert scholtes is offline
Junior Member
robert scholtes is on a distinguished road
Default
How do put the ner plastic triangle on the roller shaft ?
  #5 (permalink)
Old 11-11-2008, 07:06 PM
Senior Expert
APP Volunteer
Default
Just snap it on. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
need complete instructions to replce rear drum support rollers reddyfreddy Dryer Repair 1 05-18-2008 02:34 PM
Drum Access vns Dryer Repair 3 04-12-2008 01:30 PM
drum does not turn MUIRTER Dryer Repair 1 04-09-2008 06:30 PM
dryer drum wally gator Dryer Repair 0 11-22-2007 10:16 AM
not turning of the drum scott glynn Washer Repair 1 10-12-2007 11:51 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
