Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Whirlpool Duet Dryer Runs w/ Door Closed (http://forum.appliancepartspros.com/dryer-repair/13542-whirlpool-duet-dryer-runs-w-door-closed.html)
team-iceberg 10-27-2008 07:23 AM
I have a Whirlpool Duet electric dryer. My problem is that the dryer continues running after cycle is complete. I can take clothes out and shut door and it will start. There are no lights lit on the control panel and does not heat. Any help would be greatly appreciated.
Gene 10-27-2008 02:21 PM
What is the complete model number of the dryer?
eschw95458 01-25-2014 02:41 PM
I have a very similar situation. Did you ever find a solution to this problem?
On mine you can press start on the control panel and select a cycle and it will start and heat, but if you push stop/ cancel twice all the lights on the control panel go off but the drum continues to turn. It will stop if you open the door.
I have tried turning the breaker off and waiting a couple of minutes, but it makes no change in the behavior.
Dryer is Whirlpool Duet Model # GEW9200LW0
Thanks for any replies.
