Discuss
Bosch Nexxt 500 series dryer help
 in
Dryer Repair
I took my dryer apart to remove a piece of debris that was logged in between the guide wheel and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Bosch Nexxt 500 series dryer help
  #1 (permalink)
Old 10-24-2010, 05:43 PM
Junior Member
DougW72 is on a distinguished road
Default Bosch Nexxt 500 series dryer help
Model Number: wtmc3321us/05   Brand: Bosch   Age: 1 - 5 years
I took my dryer apart to remove a piece of debris that was logged in between the guide wheel and the drum. Now after reassembling the dryer it wont start.
The control panel lights up and when I push the start button I here a click
where the power supply is. Like a switch or relay. But it doesn't come on.
I took it back apart but found no loose connections or any obvious reason for it not to come on. I know it was working. Just before I took it apart I turned it on to listen for the sound I was told it was making.
Related Models
White Westinghouse WTR1240AQ0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR1240AS0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR430ES0 White Westinghouse/washer
White Westinghouse WTR430ES1 White Westinghouse/washer
White Westinghouse WTR430FS0 White Westinghouse/washer
General Electric WTRE6260F0GG Washer
General Electric WTRE6260F2GG Washer
General Electric WTSE4210A0WW Washer
Whirlpool WTW4750YQ0 AUTOMATIC WASHER
Whirlpool WTW4750YQ1 WASHER
Whirlpool WTW4800XQ0 AUTOMATIC WASHER
Whirlpool WTW4800XQ1 AUTOMATIC WASHER
Whirlpool WTW4800XQ2 AUTOMATIC WASHER
Whirlpool WTW4820XQ0 AUTOMATIC WASHER
Whirlpool WTW4850XQ0 WASHER
Whirlpool WTW4910XQ0 AUTOMATIC WASHER
Whirlpool WTW4910XQ1 AUTOMATIC WASHER
Whirlpool WTW4930XW0 AUTOMATIC WASHER
Whirlpool WTW4930XW1 WASHER
Whirlpool WTW4950XW0 AUTOMATIC WASHER
Whirlpool WTW4950XW1 AUTOMATIC WASHER
Whirlpool WTW4950XW2 WASHER
Whirlpool WTW5100SQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ1 AUTOMATIC WASHER
Whirlpool WTW5100VQ2 AUTOMATIC WASHER
Whirlpool WTW5200SQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ1 AUTOMATIC WASHER
Whirlpool WTW5200VQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ0 AUTOMATIC WASHER
Whirlpool WTW5300SQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ3 AUTOMATIC WASHER
Whirlpool WTW5300VW0 AUTOMATIC WASHER
Whirlpool WTW5300VW1 AUTOMATIC WASHER
Whirlpool WTW5300VW2 AUTOMATIC WASHER
Whirlpool WTW5300VW3 AUTOMATIC WASHER
Whirlpool WTW5310SQ0 AUTOMATIC WASHER
Whirlpool WTW5310VQ0 AUTOMATIC WASHER
Whirlpool WTW5320SQ0 AUTOMATIC WASHER
Whirlpool WTW5321SQ0 AUTOMATIC WASHER
Whirlpool WTW5400TQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ2 AUTOMATIC WASHER
Whirlpool WTW5500ST0 AUTOMATIC WASHER
Whirlpool WTW5500ST2 AUTOMATIC WASHER
Whirlpool WTW5500XL0 AUTOMATIC WASHER
Whirlpool WTW5500XL1 AUTOMATIC WASHER
Whirlpool WTW5500XL2 WASHER
Whirlpool WTW5500XW0 AUTOMATIC WASHER
Whirlpool WTW5500XW1 AUTOMATIC WASHER
Whirlpool WTW5500XW2 WASHER
Whirlpool WTW5505SQ0 AUTOMATIC WASHER
Whirlpool WTW5505SQ1 AUTOMATIC WASHER
Whirlpool WTW5505VQ0 AUTOMATIC WASHER
Whirlpool WTW5505VQ1 AUTOMATIC WASHER
Whirlpool WTW5510VQ0 AUTOMATIC WASHER
Whirlpool WTW5520SQ0 AUTOMATIC WASHER
Whirlpool WTW5521SQ0 AUTOMATIC WASHER
Whirlpool WTW5530SQ0 AUTOMATIC WASHER
Whirlpool WTW5540SQ0 AUTOMATIC WASHER
Whirlpool WTW5540ST0 AUTOMATIC WASHER
Whirlpool WTW5550SQ0 AUTOMATIC WASHER
Whirlpool WTW5550ST0 AUTOMATIC WASHER
Whirlpool WTW5550XW0 AUTOMATIC WASHER
Whirlpool WTW5550XW1 AUTOMATIC WASHER
Whirlpool WTW5550XW2 WASHER
Whirlpool WTW5560SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ2 AUTOMATIC WASHER
Whirlpool WTW5590ST0 AUTOMATIC WASHER
Whirlpool WTW5590ST2 AUTOMATIC WASHER
Whirlpool WTW5590VQ0 AUTOMATIC WASHER
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
  #2 (permalink)
Old 10-25-2010, 10:30 AM
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
There's a switch on the motor called a broken belt switch. When the belt is removed, this switch is activated by the pulley and the circuit to the motor is opened.
Take the back off and get to the motor. You'll see a switch with a plunger on each side. Press the plunger on the left towards the right and you should hear a click.
After this is done, the unit should run.
KC
  #3 (permalink)
Old 08-17-2011, 05:46 PM
Junior Member
kriegspire20 is on a distinguished road
Default I have close to the same problem
However, when I attempt to press the button on the left towards the right it doesn't click. I can press the right button to the left and make it click, then press the left button to the right and get a click. But I still cannot turn it back on.
I have all the lights working, but it doesn't start. If I have the Signal light on, I get a beeping sound when I press the Start button.
Any help would be greatly appreciated.
Thanks.
  #4 (permalink)
Old 08-18-2011, 06:27 PM
Senior Expert
APP Volunteer
Default
Below is the motor circuit for the WTMC dryers:
1) 120vac leaves out of the board on two brown wires that are plugged into a green plug. To check this, you'll remove the plug, start the unit and check for 120vac across the two pins.
2) The nuetral runs straight to the motor, but the hot leg goes to to non-resettable Thermal Overload Device (TOD). This TOD is near the lint filter housing and hard to get to, however, the next step will tell us if it's bad or not. The TOD would trip if the air temps near the filter rose too high, but this is unlikely, because there's a temperature sensor near the TOD that will cause the control to throw an error code if it were to get too hot.
3) Unplug the broken belt switch. Check it for 120vac coming into the plug. If you do read 120vac, the TOD is good. If not, hire someone to replace the TOD, because it's not an easy fix, i.e. it requires the removal of the drum.
4) If power is coming into your broken belt switch, but not leaving out, and resetting it doesn't resolve the issue, replace the broken belt switch. However, if power is entering and leaving the broken belt switch (when the plug is reconnected), the motor is bad, because it's the last component in the circuit.
Good Luck,
KC
  #5 (permalink)
Old 08-22-2011, 09:06 AM
Junior Member
Default
Well, as it turned out, everything was working fine with the dryer. In taking it apart to remove the debris that was stuck between the drum and the guide wheel, I must have broke or bowed the plastic wiring harness that secures the button that indicates that door is shut. The piece of plastic on the door that presses the button isn't reaching the button. So rather than take it apart again and find some way to get the harness to secure more firmly against the front, I just extended the piece of plastic by drilling a small screw into the tip to make it about 1/4 of an inch longer. It works fine now. Just like many other things, it helps if it is just a little bit longer.
Thanks for your prompt response.
  #6 (permalink)
Old 03-05-2012, 08:20 AM
Junior Member
jlongii is on a distinguished road
Smile Thanks
The advice was spot on! Saved me $200 or so. Will definitely come back to visit and recommend.
  #7 (permalink)
Old 06-02-2012, 12:42 PM
Junior Member
elamast is on a distinguished road
Thumbs up Thank you
That advice about the broken belt sensor also saved me a fortune. Thank you!!!
  #8 (permalink)
Old 12-01-2017, 05:14 PM
Junior Member
rhamersma is on a distinguished road
Talking
took apart my BOSCH Nexxt Dryer due to 2 screws getting jammed in one of the front drum rollers. I THOUGHT I had put everything back together properly until I hit the start button and all I heard was a click. Very disheartening at first as I thought I had broken something or done something wrong trying to fix the dryer in the first place.
This is the only post I could find on the subject of broken belt switches. Your solution was spot on and was the answer to my issues. Now the dryer is running as it should! Thank you KC!
KC
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
taking apart the door on a Bosch Nexxt 500 series washer jimbonator Washer Repair 1 08-07-2011 02:16 PM
BOSCH Nexxt Series Gas dryer aaa786110 Dryer Repair 3 02-10-2011 05:08 PM
Bosch Nexxt 500 Series won't heat up gatorsrule44 Dryer Repair 0 10-23-2009 09:18 PM
Bosch Nexxt 500 dryer problem ferstler Dryer Repair 0 08-28-2009 11:31 AM
Bosch Nexxt 500 series dryer skittles22 Dryer Repair 1 08-01-2009 06:37 PM
