Discuss
Burnt Wire
 in
Dryer Repair
I found a burnt wire end approx 1.5 " at the heater element connection. It broke off the connector.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Burnt Wire
  #1 (permalink)
Old 10-25-2008, 09:01 PM
pjflyidaho2 pjflyidaho2 is offline
Junior Member
pjflyidaho2 is on a distinguished road
Default Burnt Wire
Model Number: MDE3500AYW   Brand: Maytag   Age: 5 - 10 years
I found a burnt wire end approx 1.5 " at the heater element connection. It broke off the connector. It was the wire from the motor. I repaired the wire end but am concerned about any melted wire. Looking at the heater element while running it does not glow entirely, some part of it seem black/grey. Is there a resistance value I need to check for and how do I find that information? Should I be checking the thermostat at the element and what do I look for? A wire shouldn't burn because of age should it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burnt Rubber Smell & Smoke hchatton Washer Repair 1 10-24-2008 04:33 PM
Burnt red wire at terminal mpd Dryer Repair 1 05-21-2008 03:11 PM
Burnt Wire to Heating Element Trigger2 Dryer Repair 0 05-21-2008 12:10 PM
Belt burnt off geo549 Washer Repair 0 04-08-2008 02:28 PM
burnt out wire? lisaosborne Dryer Repair 1 09-19-2007 07:34 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
