crystalescozaykay
#1 Posted : Friday, October 24, 2008 4:09:19 PM(UTC)
crystalescozaykay
My dryer will not automatically turn off, I just replaced the heating element because it went bad.
What do you think is causing the dryer to not turn off?
#2 Posted : Saturday, October 25, 2008 4:06:45 PM(UTC)
Does it stop if you open the door? Does it start without pushing the Start button? What cycle did you use?
aflresco
#3 Posted : Sunday, October 26, 2008 4:28:00 PM(UTC)
aflresco
Hi Gene, I would like to tag on to this thread if it's ok. My dryer works fine except that the timer just stays where I set it and will run until I switch the knob to off Otherewise it seems to continue to operate it sounds like. My uneducated guess is the timer is bad since I took a bad lighting hit a month ago here in FL(which is very common). I just order the timer hoping that 's it. Your advice would be very appreciated.
Regards, Alfresco.
#4 Posted : Monday, October 27, 2008 10:22:48 AM(UTC)
aflresco,
Sounds like you are on the right track. Keep us posted.
