Discuss
Dryer is loud (like shoe in dryer)
 in
Dryer Repair
The dryer heats but has a loud noise sort of like a shoe in the dryer. We don't know
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer is loud (like shoe in dryer)
  #1 (permalink)
Old 10-24-2008, 10:28 AM
ilsonshine ilsonshine is offline
Junior Member
ilsonshine is on a distinguished road
Default Dryer is loud (like shoe in dryer)
Model Number: LE6100XSW0   Brand: Whirlpool   Age: More than 10 years
The dryer heats but has a loud noise sort of like a shoe in the dryer. We don't know much anything about dryers but thought we'd take a look and see what was to be seen. Took off the back panel, used vac on dust/lint and metal shavings dust particles Don't know what is causing the noise or metal shavings. Any suggestions on what it sounds like it could be? Oh, how do ya get the front panel off?
Related Models
Whirlpool LE6100XSW0
Whirlpool LE6150XSN1
Whirlpool LE6150XSW0
Whirlpool LE6150XSW1
Whirlpool LE6400XKW0
Whirlpool LE6400XPW0
Whirlpool LE6400XSW0
Whirlpool LE6405XPW0
Whirlpool LE6600XKW0
Whirlpool LE6600XPW0
Whirlpool LE6600XSW0
Whirlpool LE6605XPW0
Whirlpool LE6605XPW1
Whirlpool LE6680XKW0
Whirlpool LE6680XPW0
Whirlpool LE6680XSW0
Whirlpool LE6685XPW0
Whirlpool LE6685XPW1
Whirlpool LE6800XPW0
Whirlpool LE6800XSW0
Whirlpool LE6800XTG0
Whirlpool LE6800XTN0
Whirlpool LE6800XTW0
Whirlpool LE6805XPW0
Whirlpool LE6810XPW0
Whirlpool LE6810XSW0
Whirlpool LE6880XSW0
Whirlpool LE6880XSW1
Whirlpool LE6880XTF0
Whirlpool LE6880XTG0
Whirlpool LE6880XTG1
Whirlpool LE6880XTM0
Whirlpool LE6880XTN0
Whirlpool LE6880XTN1
Whirlpool LE6880XTW0
Whirlpool LE6880XTW1
Whirlpool LE6900XKW0
Whirlpool LE7000XKW0
Whirlpool LE7000XMW0
Whirlpool LE7000XMW1
Whirlpool LE7000XMW2
Whirlpool LE7000XPW0
Whirlpool LE7000XSW0
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0
Whirlpool LE7005XPW0
Whirlpool LE7010XPW0
Whirlpool LE7010XSW0
Whirlpool LE7080XSW0
Whirlpool LE7080XSW1
Whirlpool LE7080XTF0
Whirlpool LE7080XTG0
Whirlpool LE7080XTG1
Whirlpool LE7080XTM0
Whirlpool LE7080XTN0
Whirlpool LE7080XTN1
Whirlpool LE7080XTW0
Whirlpool LE7080XTW1
Amana LE7101LB Dryer - Ele
Amana LE7101WB Dryer - Ele
Amana LE7111LB Dryer - Ele
Amana LE7111LM Dryer - Ele
Amana LE7111WB Dryer - Ele
Amana LE7111WM Dryer - Ele
Amana LE7121LM Dryer - Ele
Amana LE7121WM Dryer - Ele
Amana LE7153LB Dryer - Ele
Amana LE7153LM Dryer - Ele
Amana LE7153WB Dryer - Ele
Amana LE7153WM Dryer - Ele
Amana LE7163LM Dryer - Ele
Amana LE7163WM Dryer - Ele
Whirlpool LE7680XMW0
Whirlpool LE7680XPW0
Whirlpool LE7680XSW0
Whirlpool LE7680XSW1
Whirlpool LE7685XPW0
Whirlpool LE7685XPW1
Whirlpool LE7700XWN0
Whirlpool LE7700XWW0
Whirlpool LE7760XWN0
Whirlpool LE7760XWW0
Whirlpool LE7800XKW0
Whirlpool LE7800XKW1
Whirlpool LE7800XMW0
Whirlpool LE7800XMW1
Whirlpool LE7800XMW2
Whirlpool LE7800XMW3
Whirlpool LE7800XPW0
Whirlpool LE7800XSW0
Whirlpool LE7800XSW1
Whirlpool LE7800XSW2
Whirlpool LE7800XSW3
Whirlpool LE7805XPW0
Whirlpool LE7810XPW0
Amana LE8107L2 Washer - Top Loading
Amana LE8107W2 Dryer - Ele
Amana LE8207L2 Washer - Top Loading
Amana LE8207L3 Washer - Top Loading
Amana LE8207W2 Dryer - Ele
Amana LE8207W2B Dryer - Ele
Amana LE8207W3 Dryer - Ele
Amana LE8217L2 Dryer - Ele
Amana LE8217W2 Dryer - Ele
Amana LE8267L2 Washer - Top Loading
Amana LE8267W2 Dryer - Ele
Amana LE8317L2 Dryer - Ele
Amana LE8317W2 Dryer - Ele
Amana LE8317W2B Dryer - Ele
Amana LE8327W Dryer - Ele
Amana LE8367L2 Washer - Top Loading
Amana LE8367W2 Dryer - Ele
Amana LE8407L2 Dryer - Ele
Amana LE8407W Dryer - Ele
Amana LE8407W2 Dryer - Ele
Amana LE8457L2 Dryer - Ele
Amana LE8457W Dryer - Ele
Amana LE8457W2 Dryer - Ele
Amana LE8467L2 Dryer - Ele
  #2 (permalink)
Old 10-24-2008, 10:53 AM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
you're gonna need some new rollers Unplug it remove the screws under lint screen grab hold of top in back just under control panel and pull forward that will release the top from the clips in front flop the top back and let it rest against wall. inside front panel are two 5/16 hex screws reomove those lift front up and off clips release belt from idler paying attention how it is looped for reassembly leave belt on drum grab a hold of belt from top of drum and using belt as a handle remove it in the rear bulkhead assy is your rollers dont remove the shaft from bulkhead just the clip in the groove and on left side you have to remove push nut and screw going into bottom of machine replace both rollers and the belt since its torn down reassemble in reverse order
__________________
  #3 (permalink)
Old 10-24-2008, 01:35 PM
Junior Member
Default
Thanks, v2k04. I'll have my hubby see if he can pull it apart when he comes home from work (oh, won't he be happy to have that to do). When I looked up the rollers and belt, an idler pulley was also mentioned. Will that need replaced too? Thanks
  #4 (permalink)
Old 10-24-2008, 01:37 PM
Junior Member
Default
Forgot to mention that when I emptied the vac after using it on the dust/lint/metal shavings I found a spring (sort of like on a pen but bigger of course). What would it go to?
  #5 (permalink)
Old 10-24-2008, 01:38 PM
Senior Expert
APP Volunteer
Default
a bad idler will usually squeal but if you want to repolace all mechanical parts you just as well
__________________
  #6 (permalink)
Old 10-24-2008, 02:25 PM
Junior Member
Default
What would the spring be from?
  #7 (permalink)
Old 10-24-2008, 02:30 PM
Senior Expert
APP Volunteer
Default
Something the from your Husbands pocket maybe? lol I didn't look up your model but 15 years ago or better Whirlpool used springs in the door they also had a cable running from the spring you could see the cables on the door when it was opened.these style dryers had a real small round door opening
__________________
  #8 (permalink)
Old 10-24-2008, 02:33 PM
Senior Expert
APP Volunteer
Default
I just looked up the model and your dryer does have springs on the door if the spring was lying in the cabinet more than likely the cable broke
__________________
  #9 (permalink)
Old 10-24-2008, 03:16 PM
Junior Member
Default
Sorry if this is a dumb ?, but when you said "remove the screws under lint screen" you were referring to a dryer with a lint screen on top (like ours) and not in the door right?
  #10 (permalink)
Old 10-28-2008, 03:12 PM
Junior Member
Default
Thanks, v2k04 for your suggestions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer makes loud squeaky noise ej1954 Dryer Repair 0 09-01-2008 08:52 AM
My dryer is making a loud noise GinaB Dryer Repair 2 04-09-2008 03:11 PM
Loud squeaky noise from dryer PeggyS Dryer Repair 2 03-23-2008 11:21 AM
maytag dryer shuts off after a few seconds and is very loud charger Dryer Repair 1 03-11-2008 02:30 PM
Dryer Makes Loud Noise kristi Dryer Repair 1 03-07-2008 05:56 PM
