Discuss
Dryer rumble
 in
Dryer Repair
We have a Maytag dryer model DE303, it is at least 17 years old and has been trouble free until
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer rumble
  #1 (permalink)
Old 10-20-2010, 05:21 PM
Junior Member
rj35pj is on a distinguished road
Default Dryer rumble
Brand: Maytag   Age: More than 10 years
We have a Maytag dryer model DE303, it is at least 17 years old and has been trouble free until yesterday. There is now a rumble when the dryer is running it appears to be coming from the fan that pushes the hot air out the exhaust. The parts are available should I repair or replace the dryer due to it's age? I am pretty handy and if I repair what is the easiest way to get to that "blower fan" since it is furtherest from the access panel in the rear of the dryer.
Or do I just let it rumble away......
Thank you in advance,
Bob
Ads By Google
  #2 (permalink)
Old 10-21-2010, 06:49 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for MAYTAG DE303 Dryer - Ele | AppliancePartsPros.com
You will be hard pressed to find a modern dryer built as good as your present one. Also other than hardware parts it looks like just abotb everything is still available.
The most common cause of a rumble is a rear support roller going out of round.
Could also be lint or something in the blower wheel causing it to vibrate as it spins.
So if it is in good shape, I would open it up and check the following and replace them as necessary.
Rear rollers/shafts, belt, idler wheel, front support glides, drum seals and other internal seals. Basically give it an overhaul.
Also give the interior a good cleaning and clean/check your vent system.
Here is a good site with basic dryer repair help.
http://www.applianceaid.com/dryers.html
__________________
  #3 (permalink)
Old 10-21-2010, 07:00 AM
Junior Member
Default
Thank you, I will do that!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrolux laundry center (stack washer/dryer) dryer won't start maddy Dryer Repair 0 09-21-2010 05:23 PM
loud rumble on high speed spin machinist doug Washer Repair 0 08-14-2010 04:27 AM
rumble thump sound garykranz Dryer Repair 1 03-03-2009 02:30 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Maytag Dryer make a dull rumble... SeannMI Dryer Repair 0 08-04-2008 10:50 AM
