phhutt
#1 Posted : Wednesday, October 20, 2010 10:47:57 AM(UTC)
phhutt
The machine was not in use for 4 months unplugged. When plugged in the readouts starting changing spontaneously and the machine went on and off by itself. I changed the logic board but it still does the same thing. Is my new logic board bad, is the entire control panel bad, or is it someting else. I can occasionally get it into diagnostic moce but it will not scroll or reset.
cheryllfshane55
#2 Posted : Saturday, November 6, 2010 5:08:34 AM(UTC)
cheryllfshane55
That happened to mine.
According to the trouble shooting manual if there lint/dust on the motor the dryer will stop after a short time.
I detached the console and the entire front panel of the dryer. Thread or hair and lint was stuck in the fan and I removed a lint ball the size of my fist from the bottom of the vent channel. I vacuumed the inside of the dryer cabinet completely. I reassembled the front panel and console.
The dryer worked for a longer period but resumed the readouts changing, beeping and turning itself on and off.
Then I ran a diagnostic and found a number "8" fault ("a button has been pressed for longer than 75 seconds") which I cleared. The troubleshooting manual suggests changing the "console with membrane."
I have ordered a "console with membrane" but haven't installed it yet because my dryer has been working properly for 24 hours.
phhutt
#3 Posted : Saturday, November 6, 2010 6:09:18 AM(UTC)
phhutt
Thank you. I finally had to replace the console with membrane as well as the control board. Now it is working properly (after over $300 in parts). I couldn't even get it into the diagnostic mode. It was really shot.
Maytag Neptune Drying Center "dd" code (Dryer Repair)
by cheryllfshane55 10/20/2010 9:48:02 AM(UTC)
Diassemble Maytag Neptune Drying Center (Dishwasher Repair)
by MaytagNeptune 12/8/2009 3:55:53 PM(UTC)
