Paulie K
#1 Posted : Tuesday, October 19, 2010 6:24:29 PM(UTC)
Paulie K
Dryer would not start. Would get buzzing sound when pushing start button. Took front of dryer off. Observed drum turning slightly when holding in start button along with a burning smell. Then turned the drum by hand while holding the start button and the drum turned at its normal speed. Repeated sequence twice with same results.
After trying a third time, do not get a buzzing and does not turn, even slightly. I am assuming the motor is a gonner, but is there anything else that may now be bad?
kayakcrzy
#2 Posted : Wednesday, October 20, 2010 4:18:41 AM(UTC)
kayakcrzy
No, that would be the motor. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Start button turns on heater but drum does not turn (Dryer Repair)
by Guest 12/16/2021 7:42:16 AM(UTC)
Dryer Heats, but drum does not turn (Dryer Repair)
by tzmango 2/21/2019 1:47:43 PM(UTC)
Dryer turns on but drum does not turn (Dryer Repair)
by brandybear25 11/22/2014 8:43:48 AM(UTC)
dryer heats but drum does not turn when turned on (Dryer Repair)
by phylli5491@gmail.com 11/7/2012 10:05:38 AM(UTC)
Washer puts water in drum does not turn only hums and water does not drain (Washer Repair)
by vsquared 6/23/2012 7:09:22 PM(UTC)
Dryer Drum does not turn (Dryer Repair)
by javvy 7/25/2011 6:26:54 PM(UTC)
Dryer Heats...but drum does not turn inside (Dryer Repair)
by nextel8 8/22/2009 11:08:54 AM(UTC)
Motor running but drum does not turn (Dryer Repair)
by chaz24 7/23/2009 5:49:25 PM(UTC)
Drum does not turn as free (Washer Repair)
by fjohnson 6/21/2009 9:34:07 AM(UTC)
by MUIRTER 4/9/2008 2:49:01 PM(UTC)
Dryer Drum Does Not Turn (Dryer Repair)
by Pike 12/17/2007 6:09:30 PM(UTC)
Light comes on, timer clicks, drum does not turn. (Dryer Repair)
by bradleyque 10/11/2007 11:43:27 AM(UTC)
