Discuss
squeaky dryer
 in
Dryer Repair
Dryer makes a real bad squeaking noise from the back. It doesn't squeak in time with the drum. Sounds
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » squeaky dryer
  #1 (permalink)
Old 09-29-2007, 01:12 PM
maytag97l maytag97l is offline
Junior Member
maytag97l is on a distinguished road
Unhappy squeaky dryer
Model Number: pyg2000aww   Brand: Maytag   Age: 5 - 10 years
Dryer makes a real bad squeaking noise from the back. It doesn't squeak in time with the drum. Sounds worse when you lean the dryer front or back. It is level. It has new glides, squeak is not consistant, loud then soft, stays loud, goes away???
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-30-2007, 03:41 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull the back access plate and check the idler pulley, probably bad. If ok pull front panel and remove drum. Check the rollers in back and the blower wheel in front. You can check parts by clicking on your model # above.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Squeaky Dryer Eliz17 Dryer Repair 1 09-24-2007 03:34 PM
squeaky belt bicpoppa Dryer Repair 2 07-27-2007 03:18 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
