Discuss
whirlpool dryer not heating
 in
Dryer Repair
It seems that after doing the continuity test part #3977393 does not read. When checking for the part there are
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer not heating
  #1 (permalink)
Old 10-22-2008, 04:50 PM
Junior Member
skats is on a distinguished road
Question whirlpool dryer not heating
Model Number: leq9508lwo   Brand: Whirlpool   Age: 1 - 5 years
It seems that after doing the continuity test part #3977393 does not read. When checking for the part there are 2 parts that are shipped.
Where does the second part go? The faulty on in above the heating
element, there is a second fuse? below which reads fine. By the dryer
duct to the outside there is another fuse which only reads 120. The
diagram is confusing. Is there another way to see the back of the dryer?
Skats
Ads By Google
Related Models
Whirlpool LEQ9508PG0 29"electric Dryer
Whirlpool LEQ9508PG1 29" Electric Dryer
Whirlpool LEQ9508PW0 29"electric Dryer
Whirlpool LEQ9508PW1 29" Electric Dryer
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
Whirlpool LER2614EW0
Whirlpool LER2614EW1
Whirlpool LER2614EW2
Whirlpool LER2614JQ0
Whirlpool LER2614JQ1
Whirlpool LER2614JQ2 29"electric Dryer
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB Range - S/c F/s Ele
Admiral LER3330AAW Range - S/c F/s Ele
Admiral LER3330AAZ Range - S/c F/s Ele
Whirlpool LER3422AN0
Whirlpool LER3422AW0
Whirlpool LER3424AW0
Whirlpool LER3622BN0
Whirlpool LER3622BW0
Whirlpool LER3622DQ1
Whirlpool LER3622DQ2
Whirlpool LER3622DZ1
Whirlpool LER3622DZ2
Whirlpool LER3622HQ0
Whirlpool LER3622HQ1
Whirlpool LER3622PQ0 Compact Electric Dryer
Whirlpool LER3622PQ1 Compact Electric Dryer
Whirlpool LER3622PQ2 Compact Electric Dryer
Whirlpool LER3624BN2
Whirlpool LER3624BN3
Whirlpool LER3624BW0
Whirlpool LER3624BW1
Whirlpool LER3624BW2
Whirlpool LER3624BW3
Whirlpool LER3624DQ0
Whirlpool LER3624DQ1
Whirlpool LER3624DQ2
Whirlpool LER3624DZ0
Whirlpool LER3624DZ2
Whirlpool LER3624EQ0
Whirlpool LER3624EQ1
Whirlpool LER3624JQ0
Whirlpool LER3624JQ1
Whirlpool LER3624JQ2 29" Electric Dryer
Whirlpool LER3624PQ0 29" Electric Dryer
Whirlpool LER3624PQ1 29" Electric Dryer
Whirlpool LER3634EW0
Whirlpool LER3634EW1
Whirlpool LER3634EW2
Whirlpool LER3634JW0
Whirlpool LER3634JW1
Admiral LER3725AAC Range - S/c F/s Ele
Whirlpool LER4434AN0
Whirlpool LER4434AN1
Whirlpool LER4434AQ0
Whirlpool LER4434AQ1
Whirlpool LER4434AW0
Whirlpool LER4434AW1
Whirlpool LER4436AN0
Whirlpool LER4436AW0
Whirlpool LER4600PQ0 29" Electric Dryer
Whirlpool LER4600PQ1 29" Electric Dryer
Whirlpool LER4624BN0
Whirlpool LER4624BN1
Whirlpool LER4624BN2
Whirlpool LER4624BQ0
Whirlpool LER4624BQ1
Whirlpool LER4624BQ2
Whirlpool LER4624BW0
Whirlpool LER4624BW1
Whirlpool LER4624BW2
Whirlpool LER4624DQ0
Whirlpool LER4624DQ1
Whirlpool LER4624DZ0
Whirlpool LER4624DZ1
Whirlpool LER4634BQ0
Whirlpool LER4634BQ1
Whirlpool LER4634BQ2
Whirlpool LER4634DQ0
Whirlpool LER4634DQ1
Whirlpool LER4634DZ0
Whirlpool LER4634DZ1
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
  #2 (permalink)
Old 10-23-2008, 03:25 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Listen there are three things to check, the element the thermal fuse, and the power. The thermal fuse is the part on the heater housing up top. The kit you got, came with the high limit thermostat, which is right next to the terminal of the element. Unplug the dryer, and put your meter on ohms. pull the wires off of the thermal fuse, that is located up top of the heater housing and check for continuity. If you get no reading, its bad. Do the same to the element. Tom ********************************************
  #3 (permalink)
Old 02-17-2011, 12:28 PM
Junior Member
EDinNC is on a distinguished road
Default
What are you calling "no reading"? When the needle moves all the way across the dial to zero. Or when the needle doesn't move and stays on infinity?
  #4 (permalink)
Old 02-17-2011, 04:22 PM
Senior Expert
APP Volunteer
Default
When the needle does not move
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dryer not heating davelions Dryer Repair 0 01-05-2010 02:31 PM
Whirlpool Dryer not heating mangboy Dryer Repair 1 08-17-2009 04:53 AM
Whirlpool dryer not heating distressed Dryer Repair 1 12-08-2008 11:26 AM
whirlpool gas dryer starts heating ajoreid Dryer Repair 1 11-23-2008 05:30 AM
whirlpool dryer just stopped heating KRO Dryer Repair 0 05-03-2008 07:52 AM
