| » Dryer stopped heating |
Model Number: GEQ9800LG1 Brand: Whirlpool Age: 5 - 10 years
Dryer suddenly stopped heating. Everything else works fine.
Replacement parts for WHIRLPOOL GEQ9800LG1 27"electric Dryer | AppliancePartsPros.com Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! Check the thermal cut-off (fuse) (Item 47 in Section 3) Should be 0 ohms. If it is blown you have to find out what caused it to go. Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it. If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow. You still have to find out why it blew. Check that the belt is OK. Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot. Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow. Check/clean your vent system. Check/clean the blower wheel. If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
__________________
It will most likely be the heater or the thermal fuse!! Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
| Display Modes | |
| Dryer stopped heating | jstayoung1 | Dryer Repair | 1 | 06-10-2010 04:47 AM |
| dryer stopped heating | atciskanik | Dryer Repair | 7 | 03-04-2010 02:36 AM |
| Dryer stopped heating | Tchamp | Dryer Repair | 1 | 03-25-2009 05:36 PM |
| Dryer stopped heating | gypsyqueen | Dryer Repair | 9 | 03-03-2009 03:09 PM |
| Dryer stopped heating | mkjaxon | Dryer Repair | 0 | 02-24-2009 07:55 AM |
