my dryer does not produce heat. 1.) the ignitor glows when the machine is on 2.) the gas meter shows gas running 3.) three fusses show continuity (one on the heat tube and two near the drum
I also have a thermostat that has 4 wire leads, what should each of the leads read? is there anything else trhat I can check.
