| » Frigidaire gas dryer stops igniting |
Model Number: FSG747GES1 Brand: Frigidaire Age: More than 10 years
Frigidaire gas dryer model FSG747GES1: burner ignites for a few mins then cycles off. When trying to ignite on further cycles, will ignite for a few seconds and then goes out. Ordered and replaced the coils. While waiting for the new coils to arrive, found a used model on Craig's list and bought for spare parts. Installed the new coils and same behavior. Changed the flame sensor and by passed the therm fuse. Again, same behavior...flame will not stay lit. The ignitor glows can hear the valve open, ignites for 1-2 seconds and then goes out. Any suggestions?..thanks in advance
Very likely the problem is a clogged dryer vent, causing the dryer to overheat. So it's cycling on the high limit thermostat instead of the operating thermostat.
Make sure the vent line is clean all the way through the vent outlet. If it goes on top of the roof, you have to call a vent cleaning guys. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Check the blower wheel. Make sure it is properly attached to the motor shaft and not blocked.
Quote:
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FSG747GES1 Frg(v0) / Gas Dryer | AppliancePartsPros.com Gene.
__________________
__________________
| Display Modes | |
| Dryer stops mid cycle, restarts, then stops | RayD | Dryer Repair | 4 | 06-07-2012 07:08 AM |
| frigidaire dryer heats, then gets too hot and stops | blove1329 | Dryer Repair | 0 | 09-29-2010 07:32 AM |
| igniter keeps igniting...and igniting... | masarik | Oven Repair (including Ranges and Cooktops) | 0 | 01-14-2009 03:02 PM |
| Frigidaire stops heating | trouts2 | Dryer Repair | 3 | 01-12-2009 09:53 AM |
| frigidaire oven igniting problems | candoman | Oven Repair (including Ranges and Cooktops) | 1 | 02-06-2008 02:38 PM |
