Discuss
dryer motor won't start
 in
Dryer Repair
kenmore dryer 110.60812990 wont start. Just replaced the motor AP3094245. It ran great for 2 days. Now it is dead.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer motor won't start
  #1 (permalink)
Old 10-11-2010, 09:35 AM
Junior Member
DanMaiullo is on a distinguished road
Default dryer motor won't start
Model Number: 110.60812990   Brand: Kenmore   Age: More than 10 years
kenmore dryer 110.60812990 wont start. Just replaced the motor AP3094245. It ran great for 2 days. Now it is dead. 250 V at the outlet and terminals on the dryer. All fuses and switches checked out okay. Heating element 9.6 ohms. Do I need a new motor again?
Thanks!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-16-2010, 04:18 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Always a possibility but it is rare that a new motor will not run.
Check the windings for continuity.
You said; you had 250 but did you check that you had both sides of the line when referenced to Neutral re: 120 volts. The motor needs 120. Perhaps you have lost Neutral.
When checking fuses etc., did you disconnect one side of the device you were measuring? This ensures that you do not read an alternate/parallel circuit path.
__________________
  #3 (permalink)
Old 10-16-2010, 07:20 AM
Junior Member
Default
Yes, disconnected the fuses and switches before checking. I will recheck the power. Wondering if the heating element resistance is correct at 9.6. There is a printed circuit board near the start switch. It looks ok but how do I check it? Received a new motor in the meantime and that doesn't work either, so I don't think the motor is the problem. I have no diagram so how do I know what contacts to check on the switches, especially the start switch?
  #4 (permalink)
Old 10-20-2010, 06:26 AM
Junior Member
Default
The power cable was a little split and corroded, so I replaced it. The dryer ran for a couple of hours and now it is dead again. I have a good 123 V at each pole on the power block. All the internal wiring looks good - no obvious shorts. What else can I check?
  #5 (permalink)
Old 10-21-2010, 06:17 AM
Senior Expert
APP Volunteer
Default
Yes this looks OK. Did you also check for a grounded element?
Remove wires from both sides and measure from each side of the coil to the frame. Both should be infinite ohms.
Note: This is just an extra check if the thermal fuse is blowing.
Other than the fuse it should not effect the nmotor starting.
It probably has nothing to do with the motor. The board is usually hooked to the moisture sensor strips and advances the timer to off when the clothes are dry.
The start switch may be a start relay unfortunately I could not confirm this from the pictures at AppliancePartsPros.
I also do not have a wiring diagram but here is a good link for Whirlpool dryers.
http://www.applianceaid.com/whirlpool-dryers.html
Take a look at #34 Wiring diagrams and then # 7, I think this will be close to yours.
It may have blown the thermal fuse so I would start there.
__________________
  #6 (permalink)
Old 10-21-2010, 07:16 AM
Junior Member
Default
Thanks for responding. I have traced all the wiring to the motor. I have 120V at the red wire coming from the power block to pin 2 on the motor and 120V at the blue wire to pin 4 on the motor. The black wire (pin 6) to the white wire (pin 5) reads 0 ohms when the start switch is pressed. The ground wire (green/yellow) checks out ok -0 ohms to neutral. The red wire at pin 1 seems to feed back into the dryer working its way through all the fuses which I rechecked. They all read 0 ohms when disconnected except the cycling thermostat. That reads 0 between the red wire connections, but about 7,000 ohms between the purple wire connections. The purple wires seem to connect the temperature select switch to the timer motor assembly. I don't know if this is right, but I'm buying a new cycling thermo because it's so cheap as well as new rollers for the drum as it seems kind of hard to turn. How do I check the motor to see if it is ok. It is brand new, and the second new one I tried in less than a week, but you never know. Oh yeah, the heating element checked out okay - no short circuit.
  #7 (permalink)
Old 10-21-2010, 07:44 AM
Senior Expert
APP Volunteer
Default
Your cycling thermostat looks OK.
One set of connections are the contacts, should be 0 ohms.
The other set is for a heating element built into the thermostat , 7000 ohms sounds bout right.
In either case this thermostat should not effect your motor.
__________________
  #8 (permalink)
Old 10-21-2010, 08:32 AM
Senior Expert
APP Volunteer
Default
I am doing a bit of guessing here but am fairly confident that I have it correct.
I am assuming that you used Neutral as the reference for all your readings.
This looks normal as it is L2 voltage. It is one side of the centrifugal switch for the heater.
This also looks normal It is L1 voltage to the common connection on the motor.
This also looks good. Those 2 points are directly across the start switch.
Yes, this is the other side of the centrifugal switch for the heater
Check from 4 to 5 for continuity. You should see about 2 ohms, this is the 2 motor windings wired in parallel.
Also if you measure to 5 or 6 you should see 120 volts when powered up. This is the L1 voltage (same as pin 4).
When you push the start button it should drop to zero. If it does not my guess would be that the door switch is toast.
The wiring diagram I linked is pretty poor quality so here is what the different connections should be.
1 - RED - heater centrifugal switch - to heater
2 - RED - heater centrifugal switch - to L2
4 - BLUE - left hand side of motor - common for both windings.
5 - ? - right hand side upper of motor - main motor winding and motor centrifugal switch
6 - BLACK - right hand side lower of motor - parallels the start switch - when the motor gets close to operating speed it disconnects the motor's start winding and connects across (parallels) the start switch so you can release the start switch and the motor keeps running.
I hope the above is more helpful than confusing.
__________________
  #9 (permalink)
Old 10-22-2010, 04:37 PM
Junior Member
Default
Your reply was very helpful. I checked the motors. The two new ones read 1.3 ohms from pins 4 to 5. The old rebuilt motor reads 1.9. So I guessed they were all ok. I powered it up and checked the voltage from pin 5 to neutral. 120V. But when the start button was pressed it did not drop to zero. So I jumpered the door switch and it did drop to zero. So I bought a new door switch and installed it. Now the motor starts but will not keep running. From everything I've read the centrifugal switch in the motor should keep the motor running after the start switch is released. Now the dryer will run for anywhere from 1 to 20 minutes before quitting, or it won't run at all unless the start switch is pressed in. I tried all three motors, same results. Could it be the drag from the drum is causing the motors to quit? Could it be the start switch? It's now a race to see if I can fix this thing before my wife goes out and buys a new one! Thanks!
  #10 (permalink)
Old 10-23-2010, 03:01 AM
Senior Expert
APP Volunteer
Default
That is correct.
I cannot see 3 motors having the same problem so it must be something external to the motor. Try rotating the drum by hand. It should turn fairly easily.
You may want to try this on a couple other dryers to get a feel for it.
This is a possibility. One scenario would be that the contacts in the switch are pitted and dropping the voltage to the motor and this low voltage is causing overheating.
The problem with this is that once the unit starts up, it switches over to the centrifugal switch and therefore they are not in circuit once the unit is running.
I am pretty well stumped on this one.
I am going to post this in the tech section.
I may have missed something that someone else will see.
Perhaps someone else has the wiring diagram for this unit and will be able to find where I went wrong.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper dryer not starting..new motor still no start skraps528 Dryer Repair 1 10-22-2008 09:26 PM
Dryer heating motor wont start crocidole67438 Dryer Repair 2 02-14-2008 02:29 AM
Dryer will not start, no noise at motor avspot Dryer Repair 3 01-26-2008 04:52 PM
Gas dryer motor hums but won't start nonqual Dryer Repair 5 12-27-2007 04:40 AM
Dryer motor is noisey and sometimes humms and doesn't start Tudeman Dryer Repair 2 07-20-2007 03:20 PM
