Discuss
Timer doesn't stop dryer
 in
Dryer Repair
My Admiral Capacity plus dryer just keeps drying. It never times out. Also, it may be over 10 years old.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Timer doesn't stop dryer
  #1 (permalink)
Old 10-10-2010, 05:21 PM
Junior Member
Reyrd is on a distinguished road
Default Timer doesn't stop dryer
Model Number: LNC7766A71   Brand: Admiral   Age: 5 - 10 years
My Admiral Capacity plus dryer just keeps drying. It never times out. Also, it may be over 10 years old. I've lost track of it's age. What part do I need to repair this?
Ads By Google
Related Models
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
Maytag LRTD17A Ref - Top Mount
  #2 (permalink)
Old 10-16-2010, 04:36 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts.
Replacement parts for LNC7766A71 models | AppliancePartsPros.com
Cannot say you will have to do more troubleshooting.
Does it not time out in both auto and timed dry modes?
Does the timer advance at all?
Most units use different circuit paths to power the timer motor in auto and timed dry modes. So if it does not advance in either mode then odds are the timer is shot. This can be confirmed by measuring the voltage across the timer motor. If it is getting 120 volts (some units use 240 volts) and not advancing the timer need replacing. Be very careful when doing this as there is 240 volts at the timer which is lethal.
If it advances in timed dry but not auto then your problem is probably elsewhere. On most units the timer gets power when the heating coil shuts off in an auto mode. A common cause of no advance is a grounded element re: it never shuts off.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run and the thermostats cannot regulate it.
If it does advance to off but never shuts off then I would say that the timer is the problem re: the on/off contacts in the timer are welded together.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Coin operated gas dryer will not stop by timer robert yang Dryer Repair 2 12-29-2010 02:17 PM
Washer timer does not stop, just keeps advancing. ErrorF002 Washer Repair 0 07-03-2010 08:36 AM
dryer dont stop a the end of timer dry pascal5884 Dryer Repair 1 03-10-2010 04:49 PM
New timer does not stop at the off position bhurley Dryer Repair 1 01-18-2010 01:12 AM
Timer will not stop running Mike Johnson Dryer Repair 0 06-04-2008 10:18 AM
