dbrooks
#1 Posted : Saturday, October 9, 2010 7:05:40 AM(UTC)
dbrooks
I opened the door to my dryer last night and when I closed the door back and tried to restart nothing happens. I can hear the timer ticking if I have in the on setting but nothing else.I checked the breakers and they are alright. Can you tell me what else I can do?
#2 Posted : Saturday, October 16, 2010 4:43:12 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG PYE4500AYW Dryer - Ele | AppliancePartsPros.com
Problem with the above is that the wiring diagram is for a gas uniy.
Below is the parts for a PYE4558 it's wiring diagram is for an electric unit and it should be close to yours.
Replacement parts for MAYTAG PYE4558AYW Dryer - Ele | AppliancePartsPros.com
[COLOR="Blue"]Can you tell me what else I can do?[/COLOR]
Since you can hear the timer we will assume that the unit is getting voltage and that the thermal fuse is OK. An additional check would be if the interior light is working or check the L1 to Neutral voltage, should be 120 volts.
Could be the following.
The door switch is not closing. Manually push it to see if the interior light goes off. If it does try starting the dryer like this. Could be it is not being closed by the door. Do not run the dryer very long with the door open as this can blow the thermal fuse. Note this test does not totally eliminate the switch as the cause. It could be that the contacts inside the switch are shot so if the above does nothing check it with a meter.
The push to start switch is not closing.
The motor is shot or has a loose/bad connection.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
