Discuss
Heat on Dryer last only approx. 5 min and then goes out
 in
Dryer Repair
We have a Whirlpool Ultimate II Gas Dryer that stopped throwing heat after 5 minutes. It tries to relight but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heat on Dryer last only approx. 5 min and then goes out
  #1 (permalink)
Old 10-09-2010, 05:13 AM
Junior Member
alcdesigns is on a distinguished road
Unhappy Heat on Dryer last only approx. 5 min and then goes out
Model Number: LGQ9557KQ0   Brand: Whirlpool   Age: 5 - 10 years
We have a Whirlpool Ultimate II Gas Dryer that stopped throwing heat after 5 minutes. It tries to relight but something in the back chatters as if it is trying to relight. It glows red but does not light. I replaced the thermal fuse and still have the same problem. I have cleaned out the vent. Any suggestions, please help.
Related Models
Whirlpool LGQ9557KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9557KT0 RESIDENTIAL DRYER
Whirlpool LGQ9557KT1 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9558KT0 RESIDENTIAL DRYER
Whirlpool LGQ9558KT1 RESIDENTIAL DRYER
Whirlpool LGQ9857LG0 RESIDENTIAL DRYER
Whirlpool LGQ9857LG1 29"GAS DRYER
Whirlpool LGQ9857LW0 RESIDENTIAL DRYER
Whirlpool LGQ9857LW1 29"GAS DRYER
Whirlpool LGQ9857PW0 29"GAS DRYER
Whirlpool LGQ9858LG0 RESIDENTIAL DRYER
Whirlpool LGQ9858LG1 29"GAS DRYER
Whirlpool LGQ9858LW0 RESIDENTIAL DRYER
Whirlpool LGQ9858LW1 29"GAS DRYER
Whirlpool LGQ9858PG0 29"GAS DRYER
Whirlpool LGQ9858PG1 29"GAS DRYER
Whirlpool LGQ9858PW0 29"GAS DRYER
Whirlpool LGQ9858PW1 29"GAS DRYER
Whirlpool LGR2614BW0 GAS DRYER
Whirlpool LGR2614BW1 GAS DRYER
Whirlpool LGR2614BW2 GAS DRYER
Whirlpool LGR2614DW0 GAS DRYER
Whirlpool LGR2614DW1 GAS DRYER
Whirlpool LGR2614EW0 GAS DRYER
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB RANGE- S/C F/S GAS
Admiral LGR3330ADW RANGE- S/C F/S GAS
Admiral LGR3330ADZ RANGE- S/C F/S GAS
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0 Residential Dryer
Whirlpool LGR3424AW0 Residential Dryer
Whirlpool LGR3622BN0 COMPACT GAS DRYER
Whirlpool LGR3622BW0 COMPACT GAS DRYER
Whirlpool LGR3622DQ1 COMPACT GAS DRYER
Whirlpool LGR3622DZ1 COMPACT GAS DRYER
Whirlpool LGR3624BN2 GAS DRYER
Whirlpool LGR3624BW0 GAS DRYER
Whirlpool LGR3624BW1 GAS DRYER
Whirlpool LGR3624BW2 GAS DRYER
Whirlpool LGR3624DQ1 GAS DRYER
Whirlpool LGR3624EQ0 GAS DRYER
Whirlpool LGR3624EQ1 GAS DRYER
Whirlpool LGR3624EQ2 GAS DRYER
Whirlpool LGR3624JQ0 GAS DRYER
Whirlpool LGR3624JQ1 RESIDENTIAL DRYER
Whirlpool LGR3624JQ2 29" GAS DRYER
Whirlpool LGR3624JQ3 29" GAS DRYER
Whirlpool LGR3624PQ0 29" GAS DRYER
Whirlpool LGR3624PQ1 29" GAS DRYER
Whirlpool LGR3634EW0 GAS DRYER
Whirlpool LGR3634EW1 GAS DRYER
Whirlpool LGR3634EW2 GAS DRYER
Whirlpool LGR3634EW3 GAS DRYER
Whirlpool LGR3634JW0 GAS DRYER
Whirlpool LGR3634JW1 RESIDENTIAL DRYER
Whirlpool LGR3634JW2 GAS DRYER
Admiral LGR3725ADC RANGE- S/C F/S GAS
Whirlpool LGR4434AN0 GAS DRYER
Whirlpool LGR4434AN1 GAS DRYER
Whirlpool LGR4434AQ0 Residential Dryer
Whirlpool LGR4434AQ1 GAS DRYER
Whirlpool LGR4434AW0 Residential Dryer
Whirlpool LGR4434AW1 GAS DRYER
Whirlpool LGR4436AW0 Residential Dryer
Whirlpool LGR4600PQ0 29" GAS DRYER
Whirlpool LGR4600PQ1 29" GAS DRYER
Whirlpool LGR4624BN0 GAS DRYER
Whirlpool LGR4624BN1 GAS DRYER
Whirlpool LGR4624BN2 GAS DRYER
Whirlpool LGR4624BQ0 GAS DRYER
Whirlpool LGR4624BQ1 GAS DRYER
Whirlpool LGR4624BQ2 GAS DRYER
Whirlpool LGR4624BW0 GAS DRYER
Whirlpool LGR4624BW1 GAS DRYER
Whirlpool LGR4624BW2 GAS DRYER
Whirlpool LGR4624DQ0 GAS DRYER
Whirlpool LGR4624DQ1 GAS DRYER
Whirlpool LGR4624DZ0 GAS DRYER
Whirlpool LGR4624DZ1 GAS DRYER
Whirlpool LGR4634BQ0 GAS DRYER
Whirlpool LGR4634BQ1 GAS DRYER
Whirlpool LGR4634BQ2 GAS DRYER
Whirlpool LGR4634DQ0 DRYERS
Whirlpool LGR4634DQ1 GAS DRYER
Whirlpool LGR4634DQO GAS DRYER
Whirlpool LGR4634DZ0 DRYERS
Whirlpool LGR4634DZO GAS DRYER
Whirlpool LGR4634EQ0 GAS DRYER
Whirlpool LGR4634EQ1 GAS DRYER
Whirlpool LGR4634EQ2 GAS DRYER
Whirlpool LGR4634EQ3 GAS DRYER
Whirlpool LGR4634EW0 GAS DRYER
Whirlpool LGR4634EZ0 GAS DRYER
Whirlpool LGR4634EZ1 GAS DRYER
Whirlpool LGR4634EZ2 GAS DRYER
Whirlpool LGR4634EZ3 GAS DRYER
Whirlpool LGR4634JQ0 GAS DRYER
Whirlpool LGR4634JQ1 GAS DRYER
Whirlpool LGR4634JQ2 GAS DRYER
Whirlpool LGR4634JQ3 29" GAS DRYER
Whirlpool LGR4634JT0 GAS DRYER
Whirlpool LGR4634JT1 GAS DRYER
Whirlpool LGR4634JT2 GAS DRYER
Whirlpool LGR4634JT3 29" GAS DRYER
Whirlpool LGR4634JZ0 GAS DRYER
Whirlpool LGR4634JZ1 GAS DRYER
Whirlpool LGR4634PQ0 29" GAS DRYER
Whirlpool LGR4634PQ1 29" GAS DRYER
Whirlpool LGR4634PT0 29" GAS DRYER
Whirlpool LGR4634PT1 29" GAS DRYER
Whirlpool LGR5434AW0 Residential Dryer
Whirlpool LGR5600HQ0 GAS DRYER
Whirlpool LGR5600HZ0 GAS DRYER
Whirlpool LGR5600JQ0 GAS DRYER
Whirlpool LGR5600JQ1 RESIDENTIAL DRYER
Whirlpool LGR5600JT0 GAS DRYER
Whirlpool LGR5600JT1 RESIDENTIAL DRYER
  #2 (permalink)
Old 12-28-2017, 08:40 PM
Junior Member
Nick.Mikhay is on a distinguished road
Default Is there gas coming out of the orifice?
It sounds like the valve is not opening to let out the gas, you did say the ignitor glows. I think you have a bad set of coils which I always check and replace before diagnosing the valve, in a similar situation. Good Luck.
  #3 (permalink)
Old 12-28-2017, 08:56 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Its a relatively cheap part.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave runs for approx 20 mins then f-9 error code winneymj Microwave Repair 1 01-16-2010 10:05 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
dryer starts thens stops approx. 30 sec. grebre2 Dryer Repair 1 04-16-2009 06:25 AM
Lint alarm sounds after approx 3 min run time creating a rift in the space time conti beachygreen Dryer Repair 0 03-11-2008 07:06 AM
Oven temp off by approx 150deg? DPalmerston Oven Repair (including Ranges and Cooktops) 0 01-18-2008 05:52 PM
