Discuss
Whirlpool Drying not starting
 in
Dryer Repair
About two months ago the gas dryer would only work when the timer was set to the minutes side. It
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Drying not starting
  #1 (permalink)
Old 10-17-2008, 02:40 PM
Junior Member
lalalandproduct is on a distinguished road
Default Whirlpool Drying not starting
Model Number: LGV6848AW0   Brand: Whirlpool   Age: 5 - 10 years
About two months ago the gas dryer would only work when the timer was set to the minutes side. It would not start if we set the timer to the other side (level of dryness.) Then about a month ago it seemed to fix itself and we were able to use both settings on the timer. Three days ago the dryer quit entirely, neither side would get it to go. Then after some poking and twisting of the dials, it started up again for about twenty minutes, and the quit for good. I can hear the timer working, and can feel a little vibration in the top console when it is on, but it does nothing.
I opened it up and took a look around, nothing obvious. I took out the thermal fuse and checked it for continuity, came up solid. Checked the thermometer, also solid. I'm a pc technician so I have some experience here, but not much with Ohmmeter, but I followed your guide and think I'm doing it correctly.
Any thoughts on what could cause this intermittent behavior? What should I check next? I'm not too sure how to go about checking the timer. Like I said, I can hear it clicking away, so it's getting some juice.
Thanks!
Related Models
Whirlpool LGV6848AW0 Residential Dryer
Whirlpool LGV6848AW1 GAS DRYER
Whirlpool LGV6848AW2 GAS DRYER
Whirlpool LGV7646AN1 GAS DRYER
Whirlpool LGV7646AN2 GAS DRYER
Whirlpool LGV7646AW0 Residential Dryer
Whirlpool LGV7646AW1 GAS DRYER
Whirlpool LGV7646AW2 GAS DRYER
Whirlpool LGV7646DQ0 GAS DRYER
Whirlpool LGV7646DQ1 GAS DRYER
Whirlpool LGV7646DZ0 GAS DRYER
Whirlpool LGV7646DZ1 GAS DRYER
Whirlpool LGV7848DQ0 GAS DRYER
Whirlpool LGV7848DQ1 GAS DRYER
Whirlpool LGV7848DZ0 GAS DRYER
Whirlpool LGV7848DZ1 GAS DRYER
Whirlpool LGV7858AN2 GAS DRYER
Whirlpool LGV7858AW0 Residential Dryer
Whirlpool LGV7858AW2 GAS DRYER
Whirlpool LGW8858HQ0 GAS DRYER
Whirlpool LGW8858HQ1 GAS DRYER
Whirlpool LHA4000W2
Whirlpool LHA5500W2
Whirlpool LHA5600W2
Whirlpool LHA5810W0
Whirlpool LHA6300W2
Whirlpool LHA6400W2
Whirlpool LHA6480W1
Whirlpool LHA7680W0
Whirlpool LHA7685W0
Whirlpool LHB3000W1
Whirlpool LHC4500W1
Whirlpool LHC4900W1
 LHD30EL Dehumidifier
 LHD45EL Dehumidifier
 LHD45ELY6 Dehumidifier
 LHD65EBL Dehumidifier
 LHD65EBLY7 Dehumidifier
 LHD65EBLY8 Dehumidifier
 LHD65EL Dehumidifier
Whirlpool LHE5700W0 Residential Dryer
Whirlpool LHE5800W1 Residential Dryer
Whirlpool LHE9800W0 Residential Dryer
Whirlpool LHE9800W1 Residential Dryer
Whirlpool LHE9800W2 Residential Dryer
Whirlpool LHI7501W0 Residential Dryer
Whirlpool LHI9801W2 Residential Dryer
Whirlpool LHW0050PQ0 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ1 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ2 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ3 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ4 COMPACT AUTOMATIC WASHER
General Electric LISR310CW0WW Washer
General Electric LISR310CW1WW Washer
Whirlpool LJD1306LQ0
Whirlpool LJD1306LT0
Bosch LK100-010
Bosch LK100-020
Bosch LK100-110
Bosch LK100-120
Bosch LK320-010
Bosch LK320-020
Bosch LK320-030
Bosch LK400-010
Bosch LK400-020
Bosch LK400-030
Amana LKG-170 ROOM AIR CONDITIONER
Amana LKG-171 ROOM AIR CONDITIONER
Amana LKG-240 ROOM AIR CONDITIONER
Amana LKG-240H ROOM AIR CONDITIONER
Amana LKG-241 ROOM AIR CONDITIONER
Amana LKG-241H ROOM AIR CONDITIONER
Amana LKG-300 ROOM AIR CONDITIONER
Amana LKG-300H ROOM AIR CONDITIONER
Amana LKG-340 ROOM AIR CONDITIONER
Amana LKG-340HE ROOM AIR CONDITIONER
Amana LKG-341 ROOM AIR CONDITIONER
Amana LKG-470 ROOM AIR CONDITIONER
Amana LKG-470HE ROOM AIR CONDITIONER
Amana LKG-471 ROOM AIR CONDITIONER
Amana LKG-471HE ROOM AIR CONDITIONER
Amana LKG-621 ROOM AIR CONDITIONER
Amana LKG601-617 ROOM AIR CONDITIONER
Amana LKG601H-617 ROOM AIR CONDITIONER
Amana LKI721 RANGE- F/S STD GAS
Amana LKU-617 RANGE- S/C S/I DDRAFT GAS
Amana LKU-617A RANGE- S/C S/I DDRAFT GAS
Bosch LL010-000
Whirlpool LLC7244AN0
Whirlpool LLC7244AQ0
Whirlpool LLC7244AW0
Whirlpool LLC7244AZ0
Whirlpool LLC7244BQ0
Whirlpool LLC7244BQ1
Whirlpool LLC7244BZ0
Whirlpool LLC7244BZ1
Whirlpool LLC8244DQ0
Whirlpool LLC8244DZ0
Whirlpool LLN8233BN0
Whirlpool LLN8233BN1
Whirlpool LLN8233BQ0
Whirlpool LLN8233BQ1
Whirlpool LLN8233BW0
Whirlpool LLN8233BW1
Whirlpool LLN8244AN0
Whirlpool LLN8244AW0
Whirlpool LLN8244BN0
Whirlpool LLN8244BW0
Admiral LLR1100AJQ RANGE- F/S STD GAS
Admiral LLR1100AJW RANGE- F/S STD GAS
Admiral LLR1415AJS RANGE- F/S STD GAS
Admiral LLR1415AJW RANGE- F/S STD GAS
Admiral LLR4451AJS RANGE- F/S STD GAS
Admiral LLR4451AJW RANGE- F/S STD GAS
Whirlpool LLR5144BQ0
Whirlpool LLR5144BQ1
Whirlpool LLR5144BW0
  #2 (permalink)
Old 10-17-2008, 03:25 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Check the door switch for proper connections and for continuity. Also check the start button for same.
  #3 (permalink)
Old 10-17-2008, 04:21 PM
Junior Member
Default
Thanks for the help.
Start button is good. Door I'm not sure how to check, but it seems it is functioning properly. When the door is closed and I hit the start button I hear the top components start to hum just a little, and the timer starts clicking (reminds me of trying to start a car with a dead battery). When I open the door it instantly stops. It also instantly stops if I turn the dial of the timer to Off. Any other thoughts?
  #4 (permalink)
Old 10-18-2008, 03:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the problem is a bad timer. Open the control panel, remove wires from BK and BU timer terminals and check for continuity across these terminals while the timer is in "on" position. If it's open then no doubt the timer has to be replaced.
- The part number for the timer is AP2973903
Here are the break down diagrams for the Whirlpool dryer Model LGV6848AW0
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #5 (permalink)
Old 10-18-2008, 04:10 PM
Junior Member
Default
Thanks for the help Gene.
I removed the wires from BK and BU and tested for continuity, but it came up good when the timer was in the "on" position, and "open" (needle didn't move) when in "off" position.
Is there something else I should test on the timer?
I really appreciate the help.
  #6 (permalink)
Old 10-19-2008, 09:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the wire from the "R1" terminal on the push to start relay. Check for 120VAC between this wire and ground while the timer is "on".
Reconnect this wire and remove the wire from the "R2" terminal. Check for 120VAC between the "R2" terminal and ground wile the timer is "on" and the start button is depressed.
Post the results.
__________________
  #7 (permalink)
Old 10-21-2008, 10:57 AM
Junior Member
Default
Thanks again Gene. Checked both to the best of my ability and the needle went to 1 on each. Not sure if I was doing it at 120VAC or not, it skipped 120 on the dial. Unfortunately for me though the family broke down and hired a professional. He came yesterday, shook the timer, and said it needed to be replaced. Thanks for all the help though! It's a great community you all have here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer Not Starting Jason83 Dryer Repair 8 01-05-2010 07:08 AM
whirlpool dryer not drying slushdog69 Dryer Repair 3 06-15-2009 07:29 AM
Whirlpool Gold - Quiet Partner 3 not starting up adammax Dishwasher Repair 0 03-03-2009 06:42 AM
whirlpool elec dryer not starting ravendonnie Dryer Repair 2 03-02-2009 07:48 AM
Whirlpool Roper Wahser starting making noise in spin dipali Washer Repair 1 01-21-2008 08:20 AM
