Discuss
gas dryer don't heat
 in
Dryer Repair
need to know how to put ignighter for my gas dryer Ads By Google Related Models Maytag  MDG4916AWW  Dryer -
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer don't heat
  #1 (permalink)
Old 10-06-2010, 02:03 PM
Junior Member
b.headley is on a distinguished road
Default gas dryer don't heat
Model Number: mdg4916aww   Brand: Maytag   Age: More than 10 years
Ads By Google
Related Models
Maytag MDG4916AWW Dryer - Gas
Maytag MDG5000BWQ Dryer - Gas
Maytag MDG5000BWW Dryer - Gas
Maytag MDG508DAWK Dryer - Gas
Maytag MDG508DAWW Dryer - Gas
Maytag MDG50MNAWW Dryer - Gas
Maytag MDG50MNVWQ Dryer - Gas
Maytag MDG50MNVWW Dryer - Gas
Maytag MDG50PN1AL Dryer - Gas
Maytag MDG50PN1AW Dryer - Gas
Maytag MDG50PN2VW Dryer - Gas
Maytag MDG50PNHWQ Dryer - Gas
Maytag MDG50PNHWW Dryer - Gas
Maytag MDG50PNTVQ Dryer - Gas
Maytag MDG50PNTVW Dryer - Gas
Maytag MDG50PNVWQ Dryer - Gas
Maytag MDG50PNVWW Dryer - Gas
Maytag MDG51PDAWW Dryer - Gas
Maytag MDG51PDSWW Dryer - Gas
Maytag MDG51PNAWW Dryer - Gas
Maytag MDG51PNSWW Dryer - Gas
Frigidaire MDG546RED0 Frg(v1) / Gas Dryer
Frigidaire MDG546RED1 Frg(v1) / Gas Dryer
Frigidaire MDG546RES0 Frg(v2) / Gas Dryer
Frigidaire MDG546RES1 Frg(v2) / Gas Dryer
Frigidaire MDG546RES2 Frg(v0) / Dryer
Frigidaire MDG546RET0 Frg(v3) / Gas Dryer
Frigidaire MDG546REW0 Frg(v4) / Gas Dryer
Frigidaire MDG546REW1 Frg(v3) / Gas Dryer
Maytag MDG5500AWQ Dryer - Gas
Maytag MDG5500AWW Dryer - Gas
Maytag MDG5806AWK Dryer - Gas
Maytag MDG5806AWW Dryer - Gas
Maytag MDG5960BWW Dryer - Gas
Maytag MDG6000AWQ Dryer - Gas
Maytag MDG6000AWW Dryer - Gas
Maytag MDG6000AXW Dryer - Gas
Maytag MDG6000BWQ Dryer - Gas
Maytag MDG6000BWW Dryer - Gas
Maytag MDG6200AWQ Dryer - Gas
Maytag MDG6200AWW Dryer - Gas
Maytag MDG6400AWQ Dryer - Gas
Maytag MDG6400AWW Dryer - Gas
Maytag MDG6460AWW Dryer - Gas
Maytag MDG6657BWQ Dryer - Gas
Maytag MDG6657BWW Dryer - Gas
Maytag MDG6700AWM Dryer - Gas
Maytag MDG6700AWW Dryer - Gas
Maytag MDG6800AWB Dryer - Gas
Maytag MDG6800AWQ Dryer - Gas
Maytag MDG6800AWW Dryer - Gas
Maytag MDG7057AWQ Dryer - Gas
Maytag MDG7057AWW Dryer - Gas
Maytag MDG7057BWQ Dryer - Gas
Maytag MDG7057BWW Dryer - Gas
Maytag MDG7400AWQ Dryer - Gas
Maytag MDG7400AWW Dryer - Gas
Maytag MDG7460AWQ Dryer - Gas
Maytag MDG7460AWW Dryer - Gas
Maytag MDG7500AWQ Dryer - Gas
Maytag MDG7500AWW Dryer - Gas
Maytag MDG75MNAWW Dryer - Gas
Maytag MDG75MNVWQ Dryer - Gas
Maytag MDG75MNVWW Dryer - Gas
Maytag MDG75PN1AW Dryer - Gas
Maytag MDG75PN2VW Dryer - Gas
Maytag MDG75PNAVW Dryer - Gas
Maytag MDG75PNHWQ Dryer - Gas
Maytag MDG75PNHWW Dryer - Gas
Maytag MDG75PNVVQ Dryer - Gas
Maytag MDG75PNVVW Dryer - Gas
Maytag MDG75PNVWQ Dryer - Gas
Maytag MDG75PNVWW Dryer - Gas
Maytag MDG7600AWQ Dryer - Gas
Maytag MDG7600AWW Dryer - Gas
Maytag MDG7657AWQ Dryer - Gas
Maytag MDG7657AWW Dryer - Gas
Maytag MDG7657BWQ Dryer - Gas
Maytag MDG7657BWW Dryer - Gas
Maytag MDG7658AWQ Dryer - Gas
Maytag MDG7658AWW Dryer - Gas
Maytag MDG7658BWQ Dryer - Gas
Maytag MDG7658BWW Dryer - Gas
Maytag MDG76PCBWS Dryer - Gas
Maytag MDG76PCBWW Dryer - Gas
Maytag MDG7757AWQ Dryer - Gas
Maytag MDG7757AWW Dryer - Gas
Maytag MDG7758AWQ Dryer - Gas
Maytag MDG7758AWW Dryer - Gas
Maytag MDG77PNAWW Dryer - Gas
Maytag MDG77PNSWW Dryer - Gas
Maytag MDG8000AWQ Dryer - Gas
Maytag MDG8000AWW Dryer - Gas
Maytag MDG8000BWQ Dryer - Gas
Maytag MDG8000BWW Dryer - Gas
Maytag MDG8057AWQ Dryer - Gas
Maytag MDG8057AWW Dryer - Gas
Maytag MDG8057BWQ Dryer - Gas
Maytag MDG8057BWW Dryer - Gas
Maytag MDG8058BWQ Dryer - Gas
Maytag MDG8058BWW Dryer - Gas
Maytag MDG8400AWQ Dryer - Gas
Maytag MDG8400AWW Dryer - Gas
Maytag MDG8416AWA Dryer - Gas
Maytag MDG8416AWW Dryer - Gas
International MDG8426AAW Dryer - Gas
International MDG8426AEW Dryer - Gas
International MDG8426AGW Dryer - Gas
Maytag MDG8500BWW Dryer - Gas
Maytag MDG8506AWA Dryer - Gas
Maytag MDG8506AWW Dryer - Gas
International MDG8550AGW Dryer - Gas
International MDG8550BGW Dryer - Gas
Maytag MDG8600AWQ Dryer - Gas
Maytag MDG8600AWW Dryer - Gas
Maytag MDG8757AWQ Dryer - Gas
Maytag MDG8757AWW Dryer - Gas
Maytag MDG9206AWA Dryer - Gas
Maytag MDG9206AWW Dryer - Gas
Maytag MDG9206AXW Dryer - Gas
  #2 (permalink)
Old 10-06-2010, 02:34 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Headley,
I take for granted you have access to the igniter,removed front panel, etc. and have unplugged the power cord.
Everybody does the same repair differently.
But basically :
Disconnect the igniter wire harness at the white connector.
With a 1/4 inch box end wrench, or socket and ratchet, loosen the small bolt holding the igniter to the mounting plate on the burner assembly, and remove igniter, by sliding towards the back of the machine.
You need to be very careful with the new part, it is very fragile.
When you install the new igniter, there's a slot on the bottom of the mounting plate, the mounting tab on the sides of the igniter insulator(white part)has to slip into that slot, and don't over tighten the mounting bolt, you could crack the new igniter,
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
