Discuss
gas dryer, no heat, what part to try next?
 in
Dryer Repair
We replaced the coils about 6 months ago when we had no heat. Worked great. No heat again. Replaced coils
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer, no heat, what part to try next?
  #1 (permalink)
Old 10-06-2010, 12:18 PM
Junior Member
minnow73 is on a distinguished road
Default gas dryer, no heat, what part to try next?
Model Number: lgr4634jq2   Brand: Whirlpool   Age: 1 - 5 years
We replaced the coils about 6 months ago when we had no heat. Worked great. No heat again. Replaced coils again, was not the problem apparently. There was no glow when we turned it on, so last night put in a new ignitor. Nothing. I want to order all the parts it may be at one time so we can get this thing FIXED! Please advise as to what parts you suggest it may be. Fuse? Flame sensor? Thank you
Ads By Google
Related Models
Whirlpool LGR4634JQ2
Whirlpool LGR4634JQ3 29" Gas Dryer
Whirlpool LGR4634JT0
Whirlpool LGR4634JT1
Whirlpool LGR4634JT2
Whirlpool LGR4634JT3 29" Gas Dryer
Whirlpool LGR4634JZ0
Whirlpool LGR4634JZ1
Whirlpool LGR4634PQ0 29" Gas Dryer
Whirlpool LGR4634PQ1 29" Gas Dryer
Whirlpool LGR4634PT0 29" Gas Dryer
Whirlpool LGR4634PT1 29" Gas Dryer
Whirlpool LGR5434AN0
Whirlpool LGR5434AW0
Whirlpool LGR5600HQ0
Whirlpool LGR5600HZ0
Whirlpool LGR5600JQ0
Whirlpool LGR5600JQ1
Whirlpool LGR5600JT0
Whirlpool LGR5600JT1
Whirlpool LGR5620KQ0
Whirlpool LGR5620KQ1
Whirlpool LGR5620KQ2 29"gas Dryer
Whirlpool LGR5624BN0
Whirlpool LGR5624BN1
Whirlpool LGR5624BN2
Whirlpool LGR5624BW0
Whirlpool LGR5624BW1
Whirlpool LGR5624BW2
Whirlpool LGR5624DQ0
Whirlpool LGR5624DQ1
Whirlpool LGR5624DW1
Whirlpool LGR5624DZ0
Whirlpool LGR5624DZ1
Whirlpool LGR5634AN0
Whirlpool LGR5634AQ0
Whirlpool LGR5634AQ1
Whirlpool LGR5634AQ2
Whirlpool LGR5634AW0
Whirlpool LGR5634DQ1
Whirlpool LGR5634EQ0
Whirlpool LGR5634EZ0
Whirlpool LGR5634LQ0
Whirlpool LGR5635LQ0 29"gas Dryer
Whirlpool LGR5635LQ1 29"gas Dryer
Whirlpool LGR5636DW0
Whirlpool LGR5636DW1
Whirlpool LGR5636EQ0
Whirlpool LGR5636EQ1
Whirlpool LGR5636EQ2
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
Whirlpool LGR5636LQ0
Whirlpool LGR5636LQ1 29"gas Dryer
Whirlpool LGR5636LT0
Whirlpool LGR5636LT1 29"gas Dryer
Whirlpool LGR5636LW0
Whirlpool LGR5636PQ0 29"gas Dryer
Whirlpool LGR5636PQ1 29"gas Dryer
Whirlpool LGR5636PT0 29"gas Dryer
Whirlpool LGR5636PT1 29"gas Dryer
Whirlpool LGR5638AN0
Whirlpool LGR5638AN1
Whirlpool LGR5638AN2
Whirlpool LGR5638AN3
Whirlpool LGR5638AW0
Whirlpool LGR5638AW1
Whirlpool LGR5638AW2
Whirlpool LGR5638AW3
Whirlpool LGR5644AN0
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2
Whirlpool LGR5644AW0
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2
Whirlpool LGR5644EQ0
Whirlpool LGR5644EQ1
Whirlpool LGR5644EQ2
Whirlpool LGR5644EQ3
Whirlpool LGR5644EZ0
Whirlpool LGR5644EZ1
Whirlpool LGR5644EZ2
Whirlpool LGR5644EZ3
Whirlpool LGR5644JQ0
Whirlpool LGR5644JQ1
Whirlpool LGR5644JQ2
Whirlpool LGR5644JQ3 29" Gas Dryer
Whirlpool LGR5644JT0
Whirlpool LGR5644JT1
Whirlpool LGR5644JT2
Whirlpool LGR5644JT3 29" Gas Dryer
Whirlpool LGR5644PQ0 29" Gas Dryer
Whirlpool LGR5644PQ1 29" Gas Dryer
Whirlpool LGR5700KQ0
Whirlpool LGR5700KQ1
Whirlpool LGR5700KT0
Whirlpool LGR5700KT1
Whirlpool LGR5848EQ0
Whirlpool LGR5848EQ1
Whirlpool LGR5848EQ2
Whirlpool LGR5848EQ3
Whirlpool LGR5848EQ4
Whirlpool LGR5848EQ5
Whirlpool LGR5848EQ6
Whirlpool LGR6611LQ0
Whirlpool LGR6611LQ1 29"gas Dryer
Whirlpool LGR6611PQ0 29" Gas Dryer
Whirlpool LGR6620PQ0 29"gas Dryer
  #2 (permalink)
Old 10-06-2010, 02:01 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Minnow,
I would reccomend (as you requested) replace the flame sensor
Part number: AP2910747
Located on the burner cone.
Also order and install the thermal fuse
Part number: AP3132867
Located on the blower housing.
Those are the only two basic, common, heat associated parts left, that you haven't replaced.
The remaining parts could be :
Timer
Temperature selector switch
Wire harness
Motor
These are not common failures, and I would not reccomend you replace these parts until you perform circuit and resistance checks with a VOM meter.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
dryer will spin with no heat - which part? darrylhunter@att.net Dryer Repair 1 05-12-2009 09:39 AM
dryer part bama3206 Dryer Repair 0 01-25-2008 02:33 PM
