Dobber3006
#1 Posted : Thursday, October 16, 2008 11:16:32 AM(UTC)
Dobber3006
My girlfriend has a compact Kenmore dryer (the model # escapes me right now) that will tumble fine but will not heat up. I took it apart and replaced the thermal fuse and the dryer would heat up for about a day but now will not heat again.
Is something faulty causing the thermal fuse to continue to blow or might my heating element be bad? I took off the heating element and it looks fine (no breaks in the wiring/coils) but I'm not sure if you can tell from looking at an element whether it's bad or not.
Help please, as my girlfriend thinks I'm Bob Vila and needs to get this dryer fixed. We hate to keep ordering parts and waiting for a week to get them just to install them and hope that they work. I would like to know what is causing the problem so we can look there and get this thing fixed.
Thanks for any help you can give.
Barton
Denver, CO
libertyappl
#2 Posted : Thursday, October 16, 2008 12:26:47 PM(UTC)
libertyappl
The thermal fuse would keep the dryer from working at all if blown. Check the wires going to the thermostats and the thermostats themselves. You might also want to check your voltage coming to the dryer.
Nat
kayakcrzy
#3 Posted : Thursday, October 16, 2008 2:18:15 PM(UTC)
kayakcrzy
Without a volt/ohm meter you will never be bob villa. You need to check power where the dryer cord goes into the dryer, and you need to ohm out the element. When you ohm out the element the dryer needs to be unplugged. Tom ApplianceEducator.com
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
