Discuss
dryer
 in
Dryer Repair
Replaced thermal cut off and high temp switch, lasted about two weeks. replaced again and lasted 2 loads. heating element
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer
  #1 (permalink)
Old 10-04-2010, 03:54 PM
Junior Member
wbhoy1 is on a distinguished road
Default dryer
Model Number: lte6234dqo   Brand: Whirlpool   Age: More than 10 years
Replaced thermal cut off and high temp switch, lasted about two weeks. replaced again and lasted 2 loads. heating element tested ok. there is 115v on all terminals
Ads By Google
Related Models
Whirlpool LTE6234DT2
Whirlpool LTE6234DT3 Washer/dryer Laundry System
Whirlpool LTE6234DT4 Washer/dryer Laundry System
Whirlpool LTE6234DT5 Washer/dryer Laundry System
Whirlpool LTE6234DT6 Washer/dryer Laundry System
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1
Whirlpool LTE6234DZ2
Whirlpool LTE7245AN0
Whirlpool LTE7245AW0
Whirlpool LTE7800W1
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB Ref - Top Mount
Admiral LTF1812ARW Ref - Top Mount
Admiral LTF1812ARZ Ref - Top Mount
Admiral LTF2112ARB Ref - Top Mount
Admiral LTF2112ARW Ref - Top Mount
Admiral LTF2112ARZ Ref - Top Mount
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
Whirlpool LVA4005W6
Whirlpool LVA4005W7
Whirlpool LVA4800W0
Whirlpool LVA4805W0
Whirlpool LVA4805W1
  #2 (permalink)
Old 10-05-2010, 04:42 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I do not have a wiring diagram for this actual unit so am doing some guessing.
Did you check for a grounded element?
This would be normal depending where the timer is set.
On most units the centrifugal switch on the motor disconnects one side of the heating coil. The timer disconnects the other side. So if the timer is set to a dry mode you will see 120 on all connections when referenced to Neutral (chassis)
You have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrolux laundry center (stack washer/dryer) dryer won't start maddy Dryer Repair 0 09-21-2010 05:23 PM
bad dryer owner breaks dryer with good intentions. arcadeforever Dryer Repair 6 04-17-2009 09:28 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
coin op dryer timer starts but dryer doesn't turn on Mike Craw Dryer Repair 4 01-10-2008 07:26 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
