Can anyone help with this one? This is a condenser dryer and dries fine but keeps getting flooded because the dryer is not pumping out at the correct time. We have replaced the float switch and the pump and the pump works fine when the dryer is started but it does not activate with the float switch. The flot switch is making good contact but after the first run of the pump does not start again. Is this a programme issue or a hardware issue? Is there a way to reset the programme or the PCB? Should the pump activate immediately the float switch is activated or is there a time delay? Could it be a faulty relay?
