Discuss
Maytag electric dryer auto dry not advancing
 in
Dryer Repair
I have a Maytag electric dryer, model MDET236AYW (serial # 10161949GN). It was taking too long (and too much electricity)
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag electric dryer auto dry not advancing
  #1 (permalink)
Old 10-03-2010, 11:48 AM
Junior Member
alaverick is on a distinguished road
Default Maytag electric dryer auto dry not advancing
Model Number: MDET236AYW   Brand: Maytag   Age: 5 - 10 years
I have a Maytag electric dryer, model MDET236AYW (serial # 10161949GN). It was taking too long (and too much electricity) to dry. I started by replacing the duct work to make sure it wasn't clogged. When that didn't work, I moved on to the cycling thermostat. It was now getting hot and moving air, however, the timer never moved. So, next I replaced the timer, and the unit appears to be drying OK, but the timer doesn't move in the "Autodry" settings. If left alone it will run all day long ($$$). There are no sensors telling this unit how much moisture is in the load, so I'm unsure what actually tells the timer to advance, and therefore I have no clue what to check. Any ideas?
Thanks in advance.
Ads By Google
Related Models
Maytag MDET236AYW Dryer - Ele
Maytag MDET236AZW Dryer - Ele
Maytag MDET336AYW Dryer - Ele
Maytag MDET336AZW Dryer - Ele
Maytag MDET446AYW Dryer - Ele
Maytag MDET446AZW Dryer - Ele
Maytag MDG100PN1 Dryer - Gas
Maytag MDG100PN1L Dryer - Gas
Maytag MDG100PN1W Dryer - Gas
Maytag MDG10CSAAL Dryer - Gas
Maytag MDG10CSAAW Dryer - Gas
Maytag MDG10CSABL Dryer - Gas
Maytag MDG10CSABW Dryer - Gas
Maytag MDG10CSAGL Dryer - Gas
Maytag MDG10CSAGW Dryer - Gas
Maytag MDG10CSAKL Dryer - Gas
Maytag MDG10CSEGL Dryer - Gas
Maytag MDG10CSEGW Dryer - Gas
Maytag MDG10DAAAL Dryer - Gas
Maytag MDG10DAAAW Dryer - Gas
Maytag MDG10DAABL Dryer - Gas
Maytag MDG10DAABW Dryer - Gas
Maytag MDG10MNAAW Dryer - Gas
International MDG10MNAGW Dryer - Gas
Maytag MDG10MNEGW Dryer - Gas
Maytag MDG10PDAAL Dryer - Gas
Maytag MDG10PDAAW Dryer - Gas
Maytag MDG10PDABL Dryer - Gas
Maytag MDG10PDABW Dryer - Gas
Maytag MDG10PDEGL Dryer - Gas
Maytag MDG10PDEGW Dryer - Gas
Maytag MDG10PRAAW Dryer - Gas
Maytag MDG10PSABW Dryer - Gas
Maytag MDG10PSAGL Dryer - Ele
Maytag MDG10PSAGW Dryer - Ele
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL Dryer - Gas
Maytag MDG11CSAAW Dryer - Gas
Maytag MDG11CSABW Dryer - Gas
Maytag MDG11CSAGL Dryer - Gas
Maytag MDG11CSAGW Dryer - Gas
Maytag MDG11CSEGL Dryer - Gas
Maytag MDG11CSEGW Dryer - Gas
Maytag MDG11MNAAW Dryer - Gas
Maytag MDG11MNAGW Dryer - Gas
Maytag MDG11MNEGW Dryer - Gas
Maytag MDG11PDAAL Dryer - Gas
Maytag MDG11PDAAW Dryer - Gas
Maytag MDG11PDABL Dryer - Gas
Maytag MDG11PDABW Dryer - Gas
Maytag MDG11PDAGL Dryer - Gas
Maytag MDG11PDAGW Dryer - Gas
Maytag MDG11PDEGL Dryer - Gas
Maytag MDG11PDEGW Dryer - Gas
Maytag MDG120P1HW Dryer - Gas
Maytag MDG120PHVW Dryer - Gas
Maytag MDG12CSAAL Dryer - Gas
Maytag MDG12CSAAW Dryer - Gas
Maytag MDG12CSABL Dryer - Gas
Maytag MDG12CSABW Dryer - Gas
Maytag MDG12CSAGW Dryer - Gas
Maytag MDG12CSEGW Dryer - Gas
Maytag MDG12MNAAW Dryer - Gas
Maytag MDG12MNAGW Dryer - Gas
Maytag MDG12MNEGW Dryer - Gas
Maytag MDG12PDAAL Dryer - Gas
Maytag MDG12PDAAW Dryer - Gas
Maytag MDG12PDABL Dryer - Gas
Maytag MDG12PDABW Dryer - Gas
Maytag MDG12PDBAL Dryer - Gas
Maytag MDG12PDBAW Dryer - Gas
Maytag MDG12PDBBL Dryer - Gas
Maytag MDG12PDBBW Dryer - Gas
Maytag MDG12PRAAW Dryer - Gas
Maytag MDG12PRBAW Dryer - Gas
Maytag MDG12PRBBW Dryer - Gas
Maytag MDG12PSABW Dryer - Gas
Maytag MDG12PSAGW Dryer - Gas
Maytag MDG12PSBAW Dryer - Gas
Maytag MDG12PSBBW Dryer - Gas
Maytag MDG13CSAAL Dryer - Gas
Maytag MDG13CSAAW Dryer - Gas
Maytag MDG13CSABW Dryer - Gas
Maytag MDG13CSAGW Dryer - Gas
Maytag MDG13CSAKL Dryer - Gas
Maytag MDG13CSEGW Dryer - Gas
Maytag MDG13MNAAW Dryer - Gas
Maytag MDG13PDAAL Dryer - Gas
Maytag MDG13PDAAW Dryer - Gas
Maytag MDG13PDABL Dryer - Gas
Maytag MDG13PDABW Dryer - Gas
Maytag MDG13PDAGW Dryer - Gas
Maytag MDG13PDBAL Dryer - Gas
Maytag MDG13PDBAW Dryer - Gas
Maytag MDG13PDBBL Dryer - Gas
Maytag MDG13PDBBW Dryer - Gas
Maytag MDG13PDEGW Dryer - Gas
Maytag MDG13PRAAW Dryer - Gas
Maytag MDG13PRBAW Dryer - Gas
Maytag MDG14PDAAL Dryer - Gas
Maytag MDG14PDAAQ Dryer - Gas
Maytag MDG14PDAAW Dryer - Gas
Maytag MDG14PDAEW Dryer - Gas
Maytag MDG14PDAGW Dryer - Gas
Maytag MDG14PDSAW Dryer - Gas
Maytag MDG14PNAEW Dryer - Gas
Maytag MDG14PNAGW Dryer - Gas
Maytag MDG14PNAWW Dryer - Gas
Maytag MDG14PNSAW Dryer - Gas
Maytag MDG14PRAWW Dryer - Gas
Maytag MDG14PRAXW Dryer - Gas
Maytag MDG14PSABW Dryer - Gas
Maytag MDG14PSAGW Dryer - Gas
Maytag MDG16CSAEW Dryer - Gas
Maytag MDG16CSAGW Dryer - Gas
Maytag MDG16CSAKA Dryer - Gas
Maytag MDG16CSAKQ Dryer - Gas
Maytag MDG16CSAWA Dryer - Gas
Maytag MDG16CSAWQ Dryer - Gas
  #2 (permalink)
Old 10-04-2010, 03:07 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG MDET236AYW Dryer - Ele | AppliancePartsPros.com
You will notice that the cycling thermostat has normally open and normally closed contacts.
The normally close contacts run the heating coil.
The normally open contacts run the timer when in an auto mode, so I would start there. Timer only gets power when the heater is turned off during a cycle.
__________________
  #3 (permalink)
Old 10-06-2010, 06:12 PM
Junior Member
Default
I'm not really sure what you're saying, but I've already replaced the cycling thermostat. So unless I received a defective part, how can that still be the issue?
  #4 (permalink)
Old 10-07-2010, 02:46 AM
Senior Expert
APP Volunteer
Default
Sorry but it did not click with me that the above meant you had replaced the thermostat.
I am not sure how to explain it better.
In auto modes the timer only advances when the heater is turned off.
You said it does not advance in "Autodry" so I am assuming that it does advance in timed dry. This tells us that the timer motor is OK.
Could be you have a grounded element. This can reduce the heater output so that it never gets hot enough and it is never turned off by the thermostat.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
Below is the circuit path for the timer motor when in autodry when the heater is turned off by the thermostat.
L1 : YL : timer #4 contacts YL to RD : : RD : 3 POSITION HEAT SWITCH L1 contacts either C or V : BU : CYCLING THERMOSTAT normally open contacts BU to OR : OR : BK : TIMER MOTOR : BK : WH/BK : DRIVE MOTOR centrifugal switch RD and WH/BK contact to YL/BK : YL/BK : PUSH TO START SWITCH S contact : YL/BK : DOOR SWITCH closed contact YL/BK to WH : Neutral
The circuit is a bit complicated so I hope the above makes sense.
__________________
  #5 (permalink)
Old 05-23-2011, 02:58 PM
Junior Member
Default Still not working properly
OK, this horse is almost dead. The wife insists this dryer is still not cycling properly. I have now replaced both thermostats, the heating element, and the timer. The timer advances when the temperature selector switch is in the "delicate" position, but not in the "regular" position. If I open the door and hold the switch, I can see the element glow, but it seems to shut off quicker than I would think it should. I could replace the selector switch (since it's the only thing I haven't), or possibly one of the thermostats was bad from the factory. I have got up twice in the morning and the dryer is still running from the night before, so she's not crazy, something is not right...
I could really use some ideas (besides buying a new dryer).
  #6 (permalink)
Old 05-25-2011, 03:30 AM
Senior Expert
APP Volunteer
Default
I am still assuming that it advances and runs OK in timed dry.
This is not a valid test because with he door open no air is pulled across the heating coils so it will over heat and the hi-limit will turn it off.
I would check the selector switch using a meter.
__________________
  #7 (permalink)
Old 03-06-2012, 04:43 PM
Junior Member
Talking Denman, please help
Denman, I know you can help me with this. I have been struggling with this Maytag MDET236AYW electric clothes dryer, for over two years. I have replaced the heating element, high-limit thermostat, cycling thermostat, timer, and temperature control switch. However, after all this, it still takes about five hours to dry a load. There is nothing left to replace!
The timer never advances (the dryer has actually been left on and running all night, I don't have to tell you that scares me). The vent is unobstructed and the blower appears to be moving plenty of air. I am at a total loss. Is it possible one of the new thermostats is bad? Which should I test? How?
Denman, do you make housecalls? :D
  #8 (permalink)
Old 03-11-2012, 06:13 AM
Senior Expert
APP Volunteer
Default
It is not out of the ordinary to get a bad part but it is strange that the problem would be exactly the same so I do not think it is a thermostat.
You could check the vent temperature output.
The Q&A for the thermostat says it should vary from 155 to 110 approximately on high (regular) heat.
I could not read the label on the back of the thermostat but it should show the specs.
I am grasping at straws here as you seem to have done everything.
Sorry I do not make house calls but it may be time to get in a pro.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag gas dryer runs forever in Auto Mode meano Dryer Repair 2 04-06-2010 04:42 AM
Maytag dryer runs continuously on timer and auto s2zeller Dryer Repair 3 10-14-2009 10:23 AM
Auto Sensing Electric Dryer mrhyde25 Dryer Repair 1 09-24-2009 02:33 PM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Maytag timer not advancing tealle Washer Repair 1 08-18-2009 05:27 PM
