Discuss
dryer will not heat
 in
Dryer Repair
Dryer works fine except it will not heat. This is an electric dryer. The heating element and sensor at the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer will not heat
  #1 (permalink)
Old 09-27-2007, 05:20 AM
ctct703 ctct703 is offline
Junior Member
ctct703 is on a distinguished road
Default dryer will not heat
Model Number: LER3624BN2   Brand: Whirlpool   Age: More than 10 years
Dryer works fine except it will not heat. This is an electric dryer. The heating element and sensor at the element both ohmn out to be good. What else?
Related Models
Whirlpool LER3624BN2
Whirlpool LER3624BN3
Whirlpool LER3624BW0
Whirlpool LER3624BW1
Whirlpool LER3624BW2
Whirlpool LER3624BW3
Whirlpool LER3624DQ0
Whirlpool LER3624DQ1
Whirlpool LER3624DQ2
Whirlpool LER3624DZ0
Whirlpool LER3624DZ2
Whirlpool LER3624EQ0
Whirlpool LER3624EQ1
Whirlpool LER3624JQ0
Whirlpool LER3624JQ1
Whirlpool LER3624JQ2 29" Electric Dryer
Whirlpool LER3624PQ0 29" Electric Dryer
Whirlpool LER3624PQ1 29" Electric Dryer
Whirlpool LER3634EW0
Whirlpool LER3634EW1
Whirlpool LER3634EW2
Whirlpool LER3634JW0
Whirlpool LER3634JW1
Admiral LER3725AAC Range - S/c F/s Ele
Whirlpool LER4434AN0
Whirlpool LER4434AN1
Whirlpool LER4434AQ0
Whirlpool LER4434AQ1
Whirlpool LER4434AW0
Whirlpool LER4434AW1
Whirlpool LER4436AN0
Whirlpool LER4436AW0
Whirlpool LER4600PQ0 29" Electric Dryer
Whirlpool LER4600PQ1 29" Electric Dryer
Whirlpool LER4624BN0
Whirlpool LER4624BN1
Whirlpool LER4624BN2
Whirlpool LER4624BQ0
Whirlpool LER4624BQ1
Whirlpool LER4624BQ2
Whirlpool LER4624BW0
Whirlpool LER4624BW1
Whirlpool LER4624BW2
Whirlpool LER4624DQ0
Whirlpool LER4624DQ1
Whirlpool LER4624DZ0
Whirlpool LER4624DZ1
Whirlpool LER4634BQ0
Whirlpool LER4634BQ1
Whirlpool LER4634BQ2
Whirlpool LER4634DQ0
Whirlpool LER4634DQ1
Whirlpool LER4634DZ0
Whirlpool LER4634DZ1
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
  #2 (permalink)
Old 09-28-2007, 02:00 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Make sure you get 230 volts to the dryer. If ok, check the thermal fuse and heating element for continuity. You can click on your model # above to get parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 0 12-06-2009 01:58 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
