Discuss
Maytag Dryer not completely heating up
 in
Dryer Repair
I have a maytag dryer that only heats up partially. I found the exhaust hose and lint vents completly full.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer not completely heating up
  #1 (permalink)
Old 09-29-2010, 05:43 AM
Junior Member
bginth is on a distinguished road
Default Maytag Dryer not completely heating up
Brand: Maytag   Age: Less than 1 year
I have a maytag dryer that only heats up partially. I found the exhaust hose and lint vents completly full. They are clean and the thermal fuse tests ok. The dryer heats up a bit but doesn't get completely hot. Any suggestions next.
  #2 (permalink)
Old 09-29-2010, 03:54 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number m,ay help others help you.
Could be a grounded element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
__________________
  #3 (permalink)
Old 09-30-2010, 05:24 AM
Junior Member
Default
It is a Maytag LGT 6634DQ1. Thanks for your response. I'll check it out.
  #4 (permalink)
Old 09-30-2010, 06:13 AM
Senior Expert
APP Volunteer
Default
Your unit looks like a gas dryer so please ignore my post.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag gas dryer is not heating adrianne Dryer Repair 1 08-11-2010 11:40 AM
Maytag dryer not heating al todd Dryer Repair 2 01-17-2010 01:53 PM
Maytag Dryer Not Heating Up prmirage Dryer Repair 0 10-22-2009 11:58 PM
Maytag Dryer not heating bytor Dryer Repair 3 01-24-2009 09:11 PM
Maytag Dryer Not Heating Jim N Dryer Repair 3 12-14-2007 10:47 AM
