Discuss
Electric dryer stopped running, drum light is on
 in
Dryer Repair
Dryer was running and stopped. Drum light turns on when you open the door. The dryer and clothes in the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric dryer stopped running, drum light is on
  #1 (permalink)
Old 10-10-2008, 12:46 PM
jolybrca jolybrca is offline
Junior Member
jolybrca is on a distinguished road
Default Electric dryer stopped running, drum light is on
Model Number: 110.62912100   Brand: Kenmore   Age: 5 - 10 years
Dryer was running and stopped. Drum light turns on when you open the door. The dryer and clothes in the dryer were warm not hot. No circuit breaker tripped. Checked the start switch it functions. Door switch functions. I don't see a thermal fuse or switch. Is there one? Is it the timer? I tried to turn all switches to see if any location would allow for it to start, timer, temp, alert, start etc. nothing happens.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-10-2008, 04:21 PM
Junior Member
Default
More info. I did locate the thermal switch, the high temp sensor and the heater coil. All checked out ok. When the start switch is pushed the timer or something in that vicinity clicks.
  #3 (permalink)
Old 10-10-2008, 04:33 PM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
You have a bad thermal on the blower housing if the lint screen pulls out the top it will be oblong whit plastic thermal fastened to housing that you hook the vent hose on if the lint screen is inside the door the thermal will be on under lint screen it is also white in color to skinny wires attached to it
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
just stopped running johnthehandyman Dryer Repair 3 09-16-2008 06:26 PM
Kenmore washer stopped running geraldsanburn Washer Repair 1 07-26-2008 09:13 PM
Kenmore dryer stopped running Riding Dryer Repair 1 03-31-2008 08:11 PM
electric dryer drum won't turn dlt1520 Dryer Repair 0 02-10-2008 08:16 AM
Light comes on, timer clicks, drum does not turn. bradleyque Dryer Repair 1 10-12-2007 03:22 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
