Last week dryer had no heat. Tried jumping fuse (3392519 Fuse, Thermal) and heat came on so I bought replacement fuse and installed. Now when dryer is cold and I start it... it will heat up fine for 5-10 minutes then the heat goes off. If I immediately try to turn it on again... no heat BUT if I wait about 15 minutes and then start it again, it will again heat upo for a few minutes. It is like it reaches a heat point and just shuts off is that maybe some form of thermostadt???? HELP?
