dadhann
#1 Posted : Saturday, September 25, 2010 4:44:12 PM(UTC)
dadhann
My dryer will not start when I push the button. Try all the "troubleshooting" suggestions and it still will not work. The light comes on when the door is open. Nothing happens when I push the start button. Thanks for the help.
#2 Posted : Monday, September 27, 2010 4:55:55 AM(UTC)
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528192.pdf
What have you tried and how have you checked the various components?
When you push the start button does it make any noise?
dadhann
#3 Posted : Monday, September 27, 2010 8:44:55 AM(UTC)
dadhann
The dryer makes no noise when the start button is pushed. Thanks for helping me.
#4 Posted : Monday, September 27, 2010 10:01:09 AM(UTC)
Since the light goes on you have the voltage to run the motor.
Best and safest way to check components is with a meter.
The most common cause of your problem is a blown thermal fuse.
This is usually mounted on the blower assembly.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Next would be the push-to-start switch and then the door switch.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
