| » Whirlpool Dryer, getting Heat on NO heat setting. |
Model Number: leq9858pw1 Brand: Whirlpool Age: 5 - 10 years
Heating element wont completely turn off on no heat cycle. I've replaced the Heating element, the temperature dial, the thermal cutoff and the thermal fuse. What am I missing.
Unplug the dryer. Remove the wires from both heating element terminals. Measure the resistance between each of terminals and the ground. The ohmmeter should be set on the lowest possible scale.
One of the wires connected to the heating element should go to the motor. Find this wire. Set the meter on the AC voltage scale. Plug the dryer and measure the voltage between this wire and the ground (the dryer is off). Post the results. Here is the Wiring diagram. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LEQ9858PW1 29"electric Dryer | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Very little heat at any setting | cousineauj | Dryer Repair | 3 | 06-07-2010 03:25 AM |
| Dryer only starts if it is on "low heat" setting | jpbarras | Dryer Repair | 1 | 05-04-2010 02:49 PM |
| frigidaire dryer doesn't heat on high setting | Alexis46 | Dryer Repair | 1 | 09-27-2009 07:55 PM |
| GE Dryer wil not heat up on anything but timed setting. | todv | Dryer Repair | 0 | 11-16-2008 05:20 PM |
| Bake setting provides no heat | adrielus | Oven Repair (including Ranges and Cooktops) | 6 | 12-18-2007 06:21 AM |
