Discuss
timer works, dryer won't start
 in
Dryer Repair
i can here the timer clicking, so i know it works. however, when i press the start button, nothing. dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » timer works, dryer won't start
  #1 (permalink)
Old 09-23-2010, 07:39 PM
Junior Member
brummy95 is on a distinguished road
Default timer works, dryer won't start
Model Number: LER5634AWO   Brand: Whirlpool   Age: More than 10 years
i can here the timer clicking, so i know it works. however, when i press the start button, nothing. dryer won't start. what could the problem be?
Related Models
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
Whirlpool LER6634DW1 ELECTRIC DRYER
Whirlpool LER6634DZ0 ELECTRIC DRYER
Whirlpool LER6634DZ1 ELECTRIC DRYER
Whirlpool LER6636PW0 29" ELECTRIC DRYER
Whirlpool LER6636PW1 29" ELECTRIC DRYER
Whirlpool LER6638DQ0 ELECTRIC DRYER
Whirlpool LER6638DQ1 ELECTRIC DRYER
Whirlpool LER6638DW0 ELECTRIC DRYER
Whirlpool LER6638DW1 ELECTRIC DRYER
Whirlpool LER6638DZ0 ELECTRIC DRYER
Whirlpool LER6638DZ1 ELECTRIC DRYER
Whirlpool LER6644DQ0 ELECTRIC DRYER
Whirlpool LER6644DQ1 ELECTRIC DRYER
Whirlpool LER6644DZ0 ELECTRIC DRYER
Whirlpool LER6644DZ1 ELECTRIC DRYER
Whirlpool LER6646BN0 ELECTRIC DRYER
Whirlpool LER6646BN1 ELECTRIC DRYER
Whirlpool LER6646BN2 ELECTRIC DRYER
Whirlpool LER6646BW0 ELECTRIC DRYER
Whirlpool LER6646BW1 ELECTRIC DRYER
Whirlpool LER6646BW2 ELECTRIC DRYER
Whirlpool LER6646DN1 ELECTRIC DRYER
Whirlpool LER6646DW1 ELECTRIC DRYER
Whirlpool LER6646PW0 29" ELECTRIC DRYER
Whirlpool LER6646PW1 29" ELECTRIC DRYER
Whirlpool LER6848AN1 ELECTRIC DRYER
  #2 (permalink)
Old 09-23-2010, 09:06 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LER5634AW0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203399125.pdf
Most likely the thermal fuse in the motor circuit has blown (item 8 in Section 3).
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Also could be:
The Push TO Start switch
Timer contacts BU/BK
or worst of all the motor itself.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer works but the timer doesn't rphserri Dryer Repair 2 09-09-2010 07:47 AM
whirlpool dryer works but timer dosen't advance glassman58 Dryer Repair 8 06-06-2010 07:37 PM
Dryer timer works, but drum doesn't turn Quincer Dryer Repair 1 06-02-2010 08:38 PM
Everything works except dryer timer advance Workhorse846 Dishwasher Repair 0 04-18-2010 12:58 PM
Dryer Won't start, nothing works drlarson Dryer Repair 1 03-11-2008 04:55 PM
