Discuss
Dryer won't start
 in
Dryer Repair
Went to start dryer, Set timer, then went to hit start button. No clicking noise like usual. Lately I needed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start
  #1 (permalink)
Old 10-08-2008, 09:21 AM
nspitz nspitz is offline
Junior Member
nspitz is on a distinguished road
Default Dryer won't start
Model Number: LGR7646DQO   Brand: Whirlpool   Age: More than 10 years
Went to start dryer, Set timer, then went to hit start button. No clicking noise like usual. Lately I needed to hold the start button for a brief time to start the dryer. The door switch seems to be functioning. Any suggestions? Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-08-2008, 09:24 AM
Junior Member
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #3 (permalink)
Old 10-08-2008, 11:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by nspitz View Post
...Lately I needed to hold the start button for a brief time to start the dryer...
Did it make a humming noise at that time?
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 10-09-2008, 08:14 AM
Junior Member
Default
No humming noise. I have replaced the starter switch and thermal fuse. Now the starter switch makes a click sound when I press it in, but still nothing. I don't know how old this dryer is and I have already spend $45 on parts. I don't want to dump money into a this dryer if it is a loosing battle. Thanks
Nancy
  #5 (permalink)
Old 10-09-2008, 05:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Nancy,
Most likely the problem is a bad motor. You have to remove the bottom panel and the idler pulley. Turn the motor pulley to see how free it's rotating. Then you have to check the motor windings for continuity according to the wiring diagram. Post the results.
Here are the break down diagrams for the Whirlpool dryer Model LGR7646DQ0
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer won't start jwithyco Dryer Repair 0 08-25-2008 12:04 PM
Dryer won't start ssouthard Dryer Repair 3 08-23-2008 07:32 PM
Dryer won't Start dennisjmay Dryer Repair 2 06-26-2008 06:29 AM
Dryer does not start jamn424 Dryer Repair 4 04-08-2008 09:20 AM
Dryer doesn't start footsie Dryer Repair 1 02-04-2008 02:21 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
