Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Please! Help to replace belt..I think! (http://forum.appliancepartspros.com/dryer-repair/12744-please-help-replace-belt-i-think.html)
5december 10-07-2008 05:40 PM
Hello!
First off I am assuming I need to replace the belt. The dryer runs quiet when empty, but squeals when loaded. If you all think this is the problem, then how do I go about getting to and changing the belt???
Thanks a lot in advance for your advice!!!
5december
SublimeMasterJW 10-07-2008 06:07 PM
glides more than likely
1 Attachment(s)
Your dryer's drum rides on plastic slides. When they get thin they start making metal to metal contact.If you wait too long to replace them then it will be costly. They do not cost that much and are easily replaced. You must get the front off to inspect them.Attachment 518
SublimeMasterJW 10-07-2008 06:08 PM
1 Attachment(s)
check it out:
Attachment 519
get this off and behind there is your glides.
SublimeMasterJW 10-07-2008 06:11 PM
1 Attachment(s)
This is what that there glide looks like when it is fresh and new:
Attachment 520
