sethrs
#1 Posted : Tuesday, September 21, 2010 9:38:15 AM(UTC)
sethrs
My dryer is making a thud sound while running. It sounds like a shoe in the dryer. I have read that the dyer slides or belt would be the first things to look at.
How do I tell if they are bad? Where can I find a service manual for this dryer.
Thanks,
Seth
#2 Posted : Tuesday, September 21, 2010 12:22:05 PM(UTC)
Setn,
You have to take the dryer apart to check the rear bearing (#12 on the diagram), the drum glide (#24) and the felt seals (#20 & #21 on the diagram).
The disassembly instructions are attached to the reply.
- The rear bearing assembly Part number: AP2142648
- The drum front glide (two are needed) Part number: AP2107932
- The upper felt seal Part number: AP3579413
- The lower felt seal Part number: AP3220737
File Attachment(s):
Dryer disassemble procedure.doc (20kb) downloaded 4 time(s).
sethrs
#3 Posted : Tuesday, September 21, 2010 2:28:19 PM(UTC)
sethrs
Since the dryer is 4 years old. Are you recommending I replace all of those parts or just any of them that look worn?
Thank you for the help.
Seth
#4 Posted : Wednesday, September 22, 2010 6:23:22 PM(UTC)
Setn,
I would replace only worn out parts. It's also a good time to clean the dryer.
