Discuss
dryer willo not turn on when pushing the button
 in
Dryer Repair
what may be the problem and what do i need to purchase to fix the problem? Ads By Google Related
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer willo not turn on when pushing the button
  #1 (permalink)
Old 10-06-2008, 08:21 AM
Junior Member
maxxor is on a distinguished road
Default dryer willo not turn on when pushing the button
Model Number: al84281   Brand: Admiral   Age: 5 - 10 years
Ads By Google
Related Models
General Electric ALA15DAM1 Room air conditioner
Amana ALD10D  Commercial Microwaves
Amana ALD10DT  Commercial Microwaves
Amana ALD10T  Commercial Microwaves
Amana ALD510  Commercial Microwaves
Amana ALD510D  Commercial Microwaves
Amana ALE120RAW Dryer - Ele
Amana ALE230RAW Dryer - Ele
Amana ALE230RCW Dryer - Ele
Amana ALE331RAC Dryer - Ele
Amana ALE331RAW Dryer - Ele
Amana ALE331RCW Dryer - Ele
Amana ALE443RAC Dryer - Ele
Amana ALE443RAW Dryer - Ele
Amana ALE443RCW Dryer - Ele
Amana ALE565SAC Dryer - Ele
Amana ALE565SAW Dryer - Ele
Amana ALE643RAC Dryer - Ele
Amana ALE643RAW Dryer - Ele
Amana ALE643RBC Dryer - Ele
Amana ALE643RBW Dryer - Ele
Amana ALE643RCW Dryer - Ele
Amana ALE665SAC Dryer - Ele
Amana ALE665SAW Dryer - Ele
Amana ALE866SAC Dryer - Ele
Amana ALE866SAW Dryer - Ele
Amana ALE866SBC Dryer - Ele
Amana ALE866SBW Dryer - Ele
Amana ALE866SCW Dryer - Ele
Amana ALE868QAW Dryer - Ele
Amana ALE868QCW Washer - Top Loading
Amana ALE956EAC Dryer - Ele
Amana ALE956EAW Dryer - Ele
Whirlpool ALF12420
Whirlpool ALF15040
Whirlpool ALF20040
Whirlpool ALF21040
Whirlpool ALF24040
Whirlpool ALFE0940
Whirlpool ALFH0820
Whirlpool ALFW0940
Amana ALG120RAW Dryer - Gas
Amana ALG230RAW Dryer - Gas
Amana ALG230RCW Dryer - Gas
Amana ALG331RAC Dryer - Gas
Amana ALG331RAW Dryer - Gas
Amana ALG331RMC Dryer - Gas
Amana ALG331RMW Dryer - Gas
Amana ALG443RAC Dryer - Gas
Amana ALG443RAW Dryer - Gas
Amana ALG443RCW Dryer - Gas
Amana ALG565SAC Dryer - Gas
Amana ALG565SAW Dryer - Gas
Amana ALG643RAC Dryer - Gas
Amana ALG643RAW Dryer - Gas
Amana ALG643RBC Dryer - Gas
Amana ALG643RBW Dryer - Gas
Amana ALG643RMC Dryer - Gas
Amana ALG643RMC1 Washer - Top Loading
Amana ALG643RMW Washer - Top Loading
Amana ALG643RMW1 Washer - Top Loading
Amana ALG665SAC Dryer - Gas
Amana ALG665SAW Dryer - Gas
Amana ALG866SAC Dryer - Gas
Amana ALG866SAW Dryer - Gas
Amana ALG866SBC Dryer - Gas
Amana ALG866SBW Dryer - Gas
Amana ALG866SCW Dryer - Gas
Amana ALG868QAW Dryer - Gas
Amana ALG868QCW Washer - Top Loading
Amana ALG956EAC Dryer - Gas
Amana ALG956EAW Dryer - Gas
Whirlpool ALJ00520
Whirlpool ALJ07520
Whirlpool ALJ10020
Whirlpool ALJ12020
Whirlpool ALJ18040
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
International ALR1100AJQ Range - F/s Std Gas
International ALR1100AJW Range - F/s Std Gas
International ALR1420BDQ Range - F/s Std Gas
International ALR1420BDW Range - F/s Std Gas
Admiral ALR1450AJW Range - F/s Std Gas
International ALR1450BJW Range - F/s Std Gas
International ALR5715QDQ Range - S/c F/s Gas
International ALR5715QDS Range - S/c F/s Gas
International ALR5715QDW Range - S/c F/s Gas
Amana ALW110RAW Washer - Top Loading
Amana ALW210RAW Washer - Top Loading
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMW Washer - Top Loading
International ALW221RJW Washer - Top Loading
Amana ALW410DAW Washer - Top Loading
Amana ALW430RAC Washer - Top Loading
Amana ALW430RAW Washer - Top Loading
Amana ALW432RAW  Washer - Top Loading
Amana ALW450QAC Washer - Top Loading
Amana ALW450QAW Washer - Top Loading
Amana ALW480DAC Washer - Top Loading
Amana ALW480DAW Washer - Top Loading
  #2 (permalink)
Old 10-06-2008, 09:14 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check the thermal fuse.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 10-07-2008, 02:15 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
The thermal fuse is located on the right side of the element. First flip your breaker for the dryer off and on a few times. Then see if it comes on. If not get a putty knife, and slide it under the top on the right side, about three inches from the end, and you will hit a clip, that will release the top. Do the same on the other side. Move the top back up against the wall, and rest it there. In the back, up top, in the middle is the element. you will see 2 white wires, follow them to the right side of the element, and you will see the thermal fuse. It is about the size of a dime. You have to take out the 1/4 inch screw that holds the element in place to release the thermal fuse bracket. The part # is LA1053. It also comes with the thermostat that sit on top of the element. Once you do all that we need to fix the real problem, that made this happen in the first place. Look inside of the front panel, about 3 inches down on the right and the left side of the front panel, and you will see a 1/4 inch screw, remove them on each side, and lean the front toward you, and take the wires off the switch, and remember where they go, and then remove the front. Now look down on the bottom of the front, in the blower housing, and clean all that lint out, Once you get it all back together, take the vent hose off the back, and clean that out too. Turn it on, and then go out side, and make sure you have good air flow. Tom ********************************************
  #4 (permalink)
Old 01-15-2009, 01:31 PM
Junior Member
ALFREDO HERNANDEZ is on a distinguished road
Default
This part came with what appeared to be three fuses. i replaced the one with a blue dot and nothing happened. was i suppose to use on of the other two?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
on/off button buzzes and does not turn on dryer epatmi Dryer Repair 2 09-20-2011 03:23 PM
Gas Dryer Drum Doesn't Turn After Pushing Button. redeyedog Dryer Repair 6 12-11-2010 12:10 PM
Dryer Not Pushing Out Hot Air lorir@zoominternet.net Dryer Repair 0 09-29-2009 12:21 PM
Pushed reset button will not turn off thelmacox Garbage Disposer Repair 1 11-03-2008 02:15 PM
Magic Chef Range will not turn off with cancel button sipnor Oven Repair (including Ranges and Cooktops) 1 07-28-2008 01:25 PM
