Discuss
Dryer takes double time to dry
 in
Dryer Repair
My GE takes double the time to dry clothes. Ducts are clean. Heat assembly heats up and then shuts down
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer takes double time to dry
  #1 (permalink)
Old 10-05-2008, 04:21 PM
rdellinger rdellinger is offline
Junior Member
rdellinger is on a distinguished road
Default Dryer takes double time to dry
Model Number: DBXR463EB1WW   Brand: GE   Age: 1 - 5 years
My GE takes double the time to dry clothes. Ducts are clean. Heat assembly heats up and then shuts down for long periods of time (longer than my patience). I have tested the thermostats with my OHM meter and the one with four connectors reads good for the double white to double blue (wide side to side) but not for the single blues from narrow side to narrow side (reads replace). I tested this thermostat with all the wires disconnected. Part number appears to be
Thermostat (4-wire) - L210-30F.
Part Number: AP2044414 made by GE
I couldn't have done any of this without this website! Totally outside what I thought I could do. My question is-------did I do this correctly? According to the info I gave is this what needs to be replaced?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-07-2008, 03:24 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
Those readings that you gave are correct, and means the thermostat is electrically good. Do this for me. Open the door of the dryer, and hold in on the door switch, and then hit the timer to heat, if that element inside glows real bright, your vent is clogged. It could be the vent to the out side, or the front of the dryer would need to come off, to check the blower assembly on the front to see if it is clogged. If the element is on, and not glowing real bright, then I would replace that thermostat. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Heats, but Takes a Long Time to Dry Clothes 95breckut Dryer Repair 7 08-28-2008 09:30 PM
Kenmore Electric dryer..takes double time to dry j-me Dryer Repair 0 02-10-2008 08:32 AM
Dryer takes a long time to dry PaulLandru Dryer Repair 0 01-19-2008 03:53 PM
Electric oven takes a long time to heat kuroda01 Oven Repair (including Ranges and Cooktops) 0 11-04-2007 08:24 AM
oven takes long time to cook Wmurky Oven Repair (including Ranges and Cooktops) 2 07-29-2007 01:01 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
