Hi I have a duet dryer that is failing to heat. I followed the troubleshooting instructions and checked the thermal fuse and the flame sensor and both appear to be ok... I then proceeded to check the gas valve coils with the following results...
Terminal 1-2 reading 1420ohms spec 1340 - 1390 Terminal 1-3 Reading 578ohms spec 535 - 585 Terminal 4-5 Reading 1317ohms spec 1170 - 1270
So my readings were out of spec but only slightly - is that enough to make the coils "bad" and therefore cause the burner to not stay lit and in some cases not light at all?
Thanks for any help !!!!!!
