Discuss
No Heat
 in
Dryer Repair
How do I get at the gas valve to put meter leads on it? It is in the front of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat
  #1 (permalink)
Old 10-04-2008, 09:34 AM
bucaro@rcn.com bucaro@rcn.com is offline
Junior Member
bucaro@rcn.com is on a distinguished road
Default No Heat
Model Number: DDG7985   Brand: GE   Age: More than 10 years
It is in the front of the dryer and I can't figure out how to get at it.
Joe Bucaro
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-04-2008, 10:43 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default open the door and remove the screws holding down the top
Either 2 or 4 screws hold down the top to the front. Remove them and you can raise the top on most models. From there you can get to the screws that hold the front on. Once you get the front off you can access the gas valve assembly. Before attempting any repairs it is a good idea to clean up the dryer. Get all the lint out and clear the vents. Most of the time you are going to have a blow fuse. This keeps the gas assembly from working and setting the dryer on fire. If all the fuses are good the the flame sensor may be open if it has no continuity then that is the problem. If your sensor is good then most likely you have a bad igniter. If your igniter is ok then them operator coils are probably bad. They will half way work and quit if they are going bad. They get real hot to the touch also if they are going bad..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
No Heat While Turning, Heat When Stopped thou msg2008 Dryer Repair 1 08-07-2008 06:08 AM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
