Discuss
Gas dryer runs but won't heat
 in
Dryer Repair
My Kenmore dryer was running but wasn't heating. I replaced it with a GE model DBB3300GA2WW, thinking the Kenmore
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer runs but won't heat
  #1 (permalink)
Old 10-04-2008, 08:54 AM
sblack sblack is offline
Junior Member
sblack is on a distinguished road
Default Gas dryer runs but won't heat
Brand: Kenmore   Age: More than 10 years
My Kenmore dryer was running but wasn't heating. I replaced it with a GE model DBB3300GA2WW, thinking the Kenmore had run its course since it is 25 years old. The GE runs but doesn't heat either. I checked the circuit breaker, but the circuit wasn't tripped. I replaced the fuse on the circuit breaker, but that wasn't the problem either. Could there be a problem with the gas line coming into the house? My other gas appliances in the house are working fine.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-07-2008, 03:41 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
The second dryer, the GE must be a used dryer. Check the glow coil on the GE, and see if it glows. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dryer runs but won't heat JWG Dryer Repair 8 07-31-2008 07:40 PM
Dryer runs but will not heat up freezer65 Dryer Repair 0 07-04-2008 01:26 PM
dryer runs but no heat ompong Dryer Repair 4 06-20-2008 07:48 PM
Dryer runs but want heat gidget Dryer Repair 0 02-02-2008 11:40 AM
Dryer runs no heat Wesley Dryer Repair 3 07-28-2007 12:23 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
