Discuss
High pitched squealing noise
 in
Dryer Repair
My gas dryer makes a high pitched squealing noise when first turned on. It stops after dryer warms. Could this
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » High pitched squealing noise
  #1 (permalink)
Old 10-03-2008, 10:09 AM
b428337 b428337 is offline
Junior Member
b428337 is on a distinguished road
Default High pitched squealing noise
Model Number: SDG405DAWN   Brand: Maytag   Age: 1 - 5 years
My gas dryer makes a high pitched squealing noise when first turned on. It stops after dryer warms. Could this be the belt?
Related Models
Maytag SDG405DAWW Dryer - Gas
Maytag SDG4606AWW Dryer - Gas
Maytag SDG505DAWQ Dryer - Gas
Maytag SDG505DAWW Dryer - Gas
Maytag SDG505DAXW Dryer - Gas
Maytag SDG515DAWW Dryer - Gas
Maytag SDG5401AWQ Dryer - Gas
Maytag SDG5401AWW Dryer - Gas
Maytag SDG5401AXW Dryer - Gas
Maytag SDG5701AWQ Dryer - Gas
Maytag SDG5701AWW Dryer - Gas
Maytag SDG5701AXW Dryer - Gas
Whirlpool SDH481B0
Whirlpool SDH501B20
Amana SDI22A Ref - SXS/I&W
Amana SDI22A-A Ref - SXS/I&W
Amana SDI22A-AG Ref - SXS/I&W
Amana SDI22A-C Ref - SXS/I&W
Amana SDI22B Ref - SXS/I&W
Amana SDI22B-A Ref - SXS/I&W
Amana SDI22B-C Ref - SXS/I&W
Amana SDI22B-G Ref - SXS/I&W
Amana SDI22B-L Ref - SXS/I&W
Amana SDI22C Ref - SXS/I&W
Amana SDI22C-A Ref - SXS/I&W
Amana SDI22C-C Ref - SXS/I&W
Amana SDI22C-G Ref - SXS/I&W
Amana SDI22C-L Ref - SXS/I&W
Amana SDI22D Ref - SXS/I&W
Amana SDI22E Ref - SXS/I&W
Amana SDI22E-1-A Ref - SXS/I&W
Amana SDI22E-1-C Ref - SXS/I&W
Amana SDI22E-A Ref - SXS/I&W
Amana SDI22E-C Ref - SXS/I&W
Amana SDI22E-G Ref - SXS/I&W
Amana SDI22E-L Ref - SXS/I&W
Amana SDI22E1 Ref - SXS/I&W
Amana SDI22E1G Ref - SXS/I&W
Amana SDI22E1L Ref - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 Ref - SXS/I&W
Amana SDI22F-1-G Ref - SXS/I&W
Amana SDI22F-1-L Ref - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA Ref - SXS/I&W
Amana SDI22FC Ref - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL Ref - SXS/I&W
Amana SDI22N Ref - SXS/I&W
Amana SDI22N-1 Ref - SXS/I&W
Amana SDI22N-1-A Ref - SXS/I&W
Amana SDI22N-1-AG Ref - SXS/I&W
Amana SDI22N-1-C Ref - SXS/I&W
Amana SDI22N-A Ref - SXS/I&W
Amana SDI22N-AG Ref - SXS/I&W
Amana SDI22N-C Ref - SXS/I&W
Amana SDI22W Ref - SXS/I&W
Amana SDI22W-A Ref - SXS/I&W
Amana SDI22W-AG Ref - SXS/I&W
Amana SDI22W-C Ref - SXS/I&W
Amana SDI22W-L Ref - SXS/I&W
Amana SDI25A Ref - SXS/I&W
  #2 (permalink)
Old 10-03-2008, 07:34 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
No, belts do not create any noises. Most likely some moving parts on the drum support have to be lubricated.
P.S. For more accurate advise we need the right model number of the dryer and the model number you posted does not come up.
__________________
  #3 (permalink)
Old 10-04-2008, 09:54 PM
Junior Member
Default
Model number is Maytag SDG405DAWW
  #4 (permalink)
Old 10-06-2008, 03:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the front panel and the front bulkhead. Check the glides (#11 on the break down diagram). Remove the drum and check both drum support rollers and the idler pulley. Replace if any is worn out or just lubricate them if condition is still good.
You can find the complete disassembly instructions in the Service Manual.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer vent making high pitched whine MrClock Dryer Repair 1 08-12-2008 08:00 PM
Squealing noise from Signature 2000 electric dryer saumila Dryer Repair 1 02-14-2008 04:57 PM
Whirlpool Imperial Washer making high pitch noise Minickhk Washer Repair 0 01-11-2008 08:36 AM
high pitched noise Raleigh Dishwasher Repair 1 12-20-2007 07:35 AM
High Pitched squeak in Dryer - AMANA Tmcjury Dryer Repair 0 11-06-2007 12:23 PM
