Discuss
Frigidaire gas dryer
 in
Dryer Repair
Could anyone tell or show me photo where the thermal fuse and ignitor located for Frigidaire gas dryer? Ads By
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire gas dryer
  #1 (permalink)
Old 10-03-2008, 05:30 AM
Junior Member
alan2275lor is on a distinguished road
Default Frigidaire gas dryer
Model Number: don't know   Brand: -brand-   Age: 1 - 5 years
Ads By Google
Related Models
Dynasty DOSS1302A Misc / Accessory
Whirlpool DP1098XRN0
Whirlpool DP1098XRN1
Whirlpool DP1098XRW0
Whirlpool DP1098XRW1
Whirlpool DP3000XRG0
Whirlpool DP3000XRN0
Whirlpool DP3000XRN1
Whirlpool DP3000XRN2
Whirlpool DP3000XRN3
Whirlpool DP3000XRN4
Whirlpool DP3000XRN6
Whirlpool DP3000XRW0
Whirlpool DP3000XRW1
Whirlpool DP3800XLW0
Whirlpool DP3800XLW1
Whirlpool DP3801XLW0
Whirlpool DP3840XPN0
Whirlpool DP3840XPN1
Whirlpool DP3840XPN2
Whirlpool DP3880XMW0
Frigidaire DP400A1 Frg(v1) / 24 " Portable Dishwasher
Frigidaire DP400PD1 Frg(v2) / 24 " Portable Dishwasher
Frigidaire DP400PW1 Tap(v4) / 24 " Portable Dishwasher
Frigidaire DP400PWD1 Kel(v10) / 24 " Portable Dishwasher
Frigidaire DP400PWL1 Frg(v2) / 24 " Portable Dishwasher
Frigidaire DP400PWW1 Frg(v1) / 24 " Portable Dishwasher
Jenn-Air DP450 Dishwasher - Convertible
Jenn-Air DP450-C Dishwasher - Convertible
Jenn-Air DP450A Dishwasher - Convertible
Jenn-Air DP450B Dishwasher - Convertible
Jenn-Air DP450G Dishwasher - Convertible
Jenn-Air DP450G-C Dishwasher - Convertible
Jenn-Air DP450L Dishwasher - Convertible
Jenn-Air DP450L-C Dishwasher - Convertible
Jenn-Air DP450W Dishwasher - Convertible
Jenn-Air DP451 Dishwasher - Convertible
Jenn-Air DP451A Dishwasher - Convertible
Jenn-Air DP451B Dishwasher - Convertible
Jenn-Air DP451G Dishwasher - Convertible
Jenn-Air DP451L Dishwasher - Convertible
Jenn-Air DP451W Dishwasher - Convertible
Jenn-Air DP470 Dishwasher - Convertible
Jenn-Air DP470A Dishwasher - Convertible
Jenn-Air DP470B Dishwasher - Convertible
Jenn-Air DP470G Dishwasher - Convertible
Jenn-Air DP470L Dishwasher - Convertible
Jenn-Air DP470W Dishwasher - Convertible
Jenn-Air DP471 Dishwasher - Convertible
Jenn-Air DP471A Dishwasher - Convertible
Jenn-Air DP471B Dishwasher - Convertible
Jenn-Air DP471G Dishwasher - Convertible
Jenn-Air DP471L Dishwasher - Convertible
Jenn-Air DP471W Dishwasher - Convertible
Jenn-Air DP476 Dishwasher - Convertible
Jenn-Air DP476A Dishwasher - Convertible
Jenn-Air DP476B Dishwasher - Convertible
Jenn-Air DP476G Dishwasher - Convertible
Jenn-Air DP476L Dishwasher - Convertible
Jenn-Air DP476W Dishwasher - Convertible
Whirlpool DP4800XMW0
Whirlpool DP4800XSG0
Whirlpool DP4800XSN0
Whirlpool DP4800XSW0
Whirlpool DP6000XRP0
Whirlpool DP6000XRP1
Whirlpool DP6000XRP2
Whirlpool DP6880XLP0
Whirlpool DP6880XLP1
Whirlpool DP6881XLP0
Whirlpool DP6881XLP1
Whirlpool DP8350XVN0
Whirlpool DP8350XVN1
Whirlpool DP8350XVN2
Whirlpool DP840CWDB0
Whirlpool DP840CWDB2
Whirlpool DP840CWDB3
Whirlpool DP840CWDB4
Whirlpool DP840CWDB5
Whirlpool DP840CWDW0
Whirlpool DP840DWGX0
Whirlpool DP840DWGX1
Whirlpool DP840DWGX2
Whirlpool DP840SWKX0
Whirlpool DP840SWPX0 Portable Dishwasher
Whirlpool DP840SWPX2 Portable Dishwasher
Whirlpool DP840SWSX0 Portable Dishwasher
Whirlpool DP8500XBN0
Whirlpool DP8500XBN1
Whirlpool DP8500XBN2
Whirlpool DP8500XTN0
Whirlpool DP8500XTN1
Whirlpool DP8500XTN2
Whirlpool DP8500XTN3
Whirlpool DP8500XTN4
Whirlpool DP8500XTN5
Whirlpool DP8500XXN0
Whirlpool DP8500XXN1
Whirlpool DP8500XXN2
Whirlpool DP8500XXN3
Whirlpool DP8700XBN1
Whirlpool DP8700XTN0
Whirlpool DP8700XTN1
Whirlpool DP8700XTN2
Whirlpool DP8700XTN3
Whirlpool DP8700XTN4
Whirlpool DP8700XTN5
Whirlpool DP8700XTW2
Whirlpool DP8700XXN0
Whirlpool DP8700XYN0
Whirlpool DP8700XYN3
Whirlpool DP8700XYN4
Whirlpool DP920PFGQ1
Whirlpool DP920PFGQ2
Whirlpool DP920PFGQ3
Whirlpool DP920PFGQ4
Whirlpool DP920PFGY0
Whirlpool DP920PFGY1
Whirlpool DP920PFGY2
Whirlpool DP920PFGY3
  #2 (permalink)
Old 10-03-2008, 05:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We need the complete model number of the dryer. You can find it on the door frame or on the top panel.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-08-2008, 08:39 AM
Junior Member
Default Dryer not heat
Hi Gene,
I have Frigidaire dryer model: FDG37GHS0. COULD YOU TELL ME HOW TO CHECK THERMOSTAT, TIMER, TEMP SELECT SWITCH, SENSOR, IGNITOR IN RESISTANCE. I OPEN THE DRYER APART, BUT DON'T KNOW HOW TO CHECK OR MEASURE THE DEVICES. I MEASURED ON IGNOTOR WITH 62 OHM, IS IT SUPPOSE TO BE THE SPECIFICATION? ALSO MEASURE TEMP SELECT SWITCH: HIGH TEMP SELECT WITH 7k OHM, MID TEMP WITH1.8k OHM, AND LOW TEMP WITH ZERO OHM. ARE THESE READING CORRECT? According to diagram: at high temp selection it should be open, at mid temp - it should be 2.4K ohm, and at low temp - it should be max of 10 ohm.
I SEE THE IGNITOR LIGHT UP FOR SECOND AND CUT OFF, AND THERE IS NO HEAT.
PLEASE HELP.
__________________
  #4 (permalink)
Old 10-08-2008, 10:07 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by alan2275lor View Post
...I SEE THE IGNITOR LIGHT UP FOR SECOND AND CUT OFF, AND THERE IS NO HEAT...
The first failure suspect are the gas valve coils.
- The part number for the set of coils is AP2150379
__________________
  #5 (permalink)
Old 10-08-2008, 10:32 AM
Junior Member
Hi Gene,
Is there any possible way to check to see if the gas valve coils good or bad? can it be measured with DMM?
__________________
  #6 (permalink)
Old 10-08-2008, 10:47 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The coil with two terminals should have 1220 ± 50 Ohms.
The coil with three terminals, if held with terminals in upper position:
a). across the left and the middle terminals - 1365 ± 25 Ohms
b). across the right and the left terminals - 560 ± 25 Ohms.
__________________
  #7 (permalink)
Old 10-08-2008, 11:53 AM
Junior Member
Default Dryer not heat...
Gene,
what about thermostat heat control, sensor,and ignitor? I want to make sure these aparts measure fine before replace them.
And what about temp selection switch?
__________________
  #8 (permalink)
Old 10-08-2008, 12:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think there is something wrong with these parts. I would start with the gas valve coils unless you want to replace everything. Don't make it more complicated than it is.
__________________
  #9 (permalink)
Old 10-10-2008, 07:28 AM
Junior Member
Hi Gene,
Your support was helpful, I found my secondary coil burn. I replaced the part and now my dryer is backed to normal operation. My wife is happy and thanks for your great job.
__________________
  #10 (permalink)
Old 10-10-2008, 06:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You're welcome. I'm glad you were able to fix it and a happy wife is most important.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire dryer Kenfixit Dryer Repair 6 06-23-2012 11:14 AM
Frigidaire Dryer Richard Saenz Dryer Repair 2 06-29-2009 08:12 PM
frigidaire dryer ambrosjim Dryer Repair 1 06-20-2009 10:52 AM
frigidaire dryer jawalker85 Dryer Repair 2 05-16-2009 07:29 PM
Frigidaire dryer Darryl Brown Dryer Repair 1 03-11-2009 07:54 PM
