Discuss
losing heat in dryer!!
 in
Dryer Repair
My dryer starts initially like it should. But after running for about 5-10 min. it is "losing"
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » losing heat in dryer!!
  #1 (permalink)
Old 10-01-2008, 08:11 AM
nova70man nova70man is offline
Junior Member
nova70man is on a distinguished road
Unhappy losing heat in dryer!!
Model Number: 110.72612101   Brand: Kenmore   Age: 1 - 5 years
My dryer starts initially like it should. But after running for about 5-10 min. it is "losing" heat. It seems to be about half the temp. it should be. I have cleaned the whole unit out. Unhooked the air discharge and still does the same thing.
I have also replaced the cycling thermostat. It did not help.
Anybody have any ideas??
Thanks!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-01-2008, 04:07 PM
iamigor5@yahoo.com iamigor5@yahoo.com is offline
Senior Expert
APP Volunteer
iamigor5@yahoo.com is on a distinguished road
Default
you may want to pull the heater and check it visually. not with a meter....coil may have broken and grounded to housing
  #3 (permalink)
Old 10-01-2008, 04:15 PM
Junior Member
Default
Quote:
Coil for the gas valve?
Thanks for the reply.
  #4 (permalink)
Old 10-01-2008, 04:24 PM
Senior Expert
APP Volunteer
Default
sorry its been a long day, sounds like the gas valves are dropping out this is a common problem.if you can watch it while its running you will probably see that its only lighting every few cycles... glow bar works but no gas.its better to replace both coils at same time,by the way 70 nova brings back old memories of my nova
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
Freezer is losing cold, frig is warm mark822 Refrigerator & Freezer Repair 0 08-06-2008 07:15 PM
Dryer will not heat emcme Dryer Repair 0 04-26-2008 12:48 PM
Dryer won't heat tomhickey Dryer Repair 1 12-23-2007 11:41 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
