Discuss
dryer cuts off after 10 minutes but will start
 in
Dryer Repair
when you turn the dryer on after 10 minutes the dryer will cut off, then when you push the start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer cuts off after 10 minutes but will start
  #1 (permalink)
Old 10-01-2008, 06:01 AM
30tredog 30tredog is offline
Junior Member
30tredog is on a distinguished road
Default dryer cuts off after 10 minutes but will start
Model Number: RES7646KQ2   Brand: Roper   Age: 1 - 5 years
when you turn the dryer on after 10 minutes the dryer will cut off, then when you push the start button it will come back on and run for another 10 minutes, and cut off again, and it will constantaly do that, i replaced the thermal fuse and the thermostat, because it would not cut on at all once i replaced those it began running
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-01-2008, 06:17 AM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Did you replace both thermostats on the heater box? There are actually 3 thermostats and the thermal fuse? which did you replace?
nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 10-01-2008, 07:08 PM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
Check the door switch arm, and make sure it is hitting the door all the way. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer cuts off after 10 minutes but will start 30tredog Dryer Repair 1 09-30-2008 06:04 PM
kenmore dryer heat cuts out after a few minutes stumpedagain Dryer Repair 0 08-22-2008 08:06 PM
76 Viking Chest Freezer sometimes cuts out in start cycle viking1 Refrigerator & Freezer Repair 0 05-24-2008 04:19 PM
wash cycle stops 10 minutes after start fullhouse Washer Repair 1 03-20-2008 05:46 PM
Kenmore Dryer comes on for 10 min then cuts off lynngough Dryer Repair 0 01-23-2008 07:05 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
