Discuss
Dryer runs no heat
 in
Dryer Repair
I recently moved and had to hook up a 220 outlet for my dryer plugged it in and found it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer runs no heat
  #1 (permalink)
Old 07-24-2007, 02:54 PM
Wesley Wesley is offline
Junior Member
Wesley is on a distinguished road
Default Dryer runs no heat
Model Number: LER7620KQ1   Brand: Whirlpool   Age: 5 - 10 years
I recently moved and had to hook up a 220 outlet for my dryer plugged it in and found it did not heat. I went down and reset the 30amp double pull breaker and still no luck. I tested the outlet with a meter and it read 120-124 on each hot wire and at the same at the terminal block. I am no electrical genius abd am not very confident on how to properly test omhs. I checked the power cord and showed 0 so that means that it is closed and good. NOt sure if I am saying it right. I also replaced the heating element. Still no heat. I am looking for advice on how to properly check the thermostats and fuse for continuty.
Related Models
Whirlpool LER7620KQ1
Whirlpool LER7620KT0
Whirlpool LER7620KT1
Whirlpool LER7620LG0
Whirlpool LER7620LG1 29"electric Dryer
Whirlpool LER7620LQ0
Whirlpool LER7620LW0
Whirlpool LER7620LW1 29"electric Dryer
Whirlpool LER7646AN0
Whirlpool LER7646AN1
Whirlpool LER7646AN2
Whirlpool LER7646AQ0
Whirlpool LER7646AQ1
Whirlpool LER7646AQ2
Whirlpool LER7646AW0
Whirlpool LER7646AW1
Whirlpool LER7646AW2
Whirlpool LER7646AZ0
Whirlpool LER7646AZ1
Whirlpool LER7646AZ2
Whirlpool LER7646DQ0
Whirlpool LER7646DQ1
Whirlpool LER7646DW0
Whirlpool LER7646DW1
Whirlpool LER7646DZ0
Whirlpool LER7646DZ1
Whirlpool LER7646EQ0
Whirlpool LER7646EQ1
Whirlpool LER7646EQ2
Whirlpool LER7646EZ0
Whirlpool LER7646EZ1
Whirlpool LER7646EZ2
Whirlpool LER7646JQ0
Whirlpool LER7646JT0
Whirlpool LER7648KQ0
Whirlpool LER7648KQ1
Whirlpool LER7648KQ2
Whirlpool LER7648KQ3 29"electric Dryer
Whirlpool LER7648KT0
Whirlpool LER7648KT1
Whirlpool LER7648KT2
Whirlpool LER7648KT3 29"electric Dryer
Whirlpool LER7648PQ0 29" Electric Dryer
Whirlpool LER7648PQ1 29" Electric Dryer
Whirlpool LER7648PT0 29" Electric Dryer
Whirlpool LER7648PT1 29" Electric Dryer
Whirlpool LER7848DQ0
Whirlpool LER7848DQ1
Whirlpool LER7848DZ0
Whirlpool LER7848DZ1
Whirlpool LER7858AN0
Whirlpool LER7858AN1
Whirlpool LER7858AN2
Whirlpool LER7858AW0
Whirlpool LER7858AW1
Whirlpool LER7858AW2
Whirlpool LER8620PG0 29"electric Dryer
Whirlpool LER8620PG1 29"electric Dryer
Whirlpool LER8620PW0 29"electric Dryer
Whirlpool LER8620PW1 29"electric Dryer
Whirlpool LER8648LG0
Whirlpool LER8648LG1 29"electric Dryer
Whirlpool LER8648LQ0
Whirlpool LER8648LW0
Whirlpool LER8648LW1 29"electric Dryer
Whirlpool LER8648PG0 29"electric Dryer
Whirlpool LER8648PG1 29"electric Dryer
Whirlpool LER8648PQ0 29" Electric Dryer
Whirlpool LER8648PQ1 29"electric Dryer
Whirlpool LER8648PW0 29"electric Dryer
Whirlpool LER8648PW1 29"electric Dryer
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
  #2 (permalink)
Old 07-25-2007, 12:13 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Wesley
Before we start to check the dryer parts I would like to know how you measured the power from the outlet? There's supposed to be a 120V across each of the hot wires and the neutral wire, and 240V across both hot wires. Please, double check it and then we will go from there.
  #3 (permalink)
Old 07-25-2007, 01:33 PM
rtranfaglia rtranfaglia is offline
Junior Member
rtranfaglia is on a distinguished road
Post Dryer doesn't maintain heat throughout cycle
I have a Whirlpool Gas Dryer, model LGQ8800JQ1. It runs through entire cycle but clothes are not completely dry at the end and we need to run multiple cycle. I have checked the vent for blockage and run a cycle with it dosconnected, same result. I check continuity of most components as sugested and resistance of valve coils, all appears fine. What could be the issue?
  #4 (permalink)
Old 07-28-2007, 12:23 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
rtranfaglia
In such situation are possible two things: if there is cold inside the dryer at the end of the cycle there is no doubt the problem is a bad gas valve coils. Even their resistance reads as good they could malfunction after heat up.
If there is warm inside at the end of the cycle there is a problem with ventilation and if you did run the dryer with vent hose disconnected and result was the same then you have to take the dryer apart and clean all air ducts inside from the lint and make sure the blower wheel is fine.
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer has no heat but runs Ron L. Dryer Repair 7 06-15-2009 12:12 PM
dryer heat karen Dryer Repair 0 07-23-2007 01:55 PM
