Discuss
whirlpool dryer no heat
 in
Dryer Repair
No heat but element looks OK. Also timer doesn't work. New timer did not help. Any ideas?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer no heat
  #1 (permalink)
Old 09-30-2008, 01:51 PM
looie looie is offline
Junior Member
looie is on a distinguished road
Default whirlpool dryer no heat
Model Number: LER8620PW0   Brand: Whirlpool   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-30-2008, 03:25 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
does the dryer drum turn?
Have you tried all settings/cycles?
Test the thermstats on the heater box with an ohm meter for continuity.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-30-2008, 05:56 PM
Junior Member
Default
Drum turns, no settings work (time or heat), thermostats and element test good. When I replaced timer did I just get a bad one? Anything else I could check? Much appreciated!
  #4 (permalink)
Old 09-30-2008, 08:54 PM
Senior Expert
APP Volunteer
Default
Check your plug to make sure you have 220V. And check your breaker turn it off and then back on, sometimes they can be parially tripped and look normal.
Nat
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dryer - no heat verruckt Dryer Repair 15 12-14-2008 05:26 PM
Whirlpool Dryer won't heat up jmrobeck Dryer Repair 0 09-02-2008 12:59 PM
Whirlpool dryer won't heat haddy Dryer Repair 15 08-21-2008 05:20 PM
Whirlpool gas dryer will not heat. brae Dryer Repair 2 04-24-2008 08:21 AM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
